ozlaceuk
  • 12
Message 1 of 28
Just installed the Hub4 and not getting promised speed
We installed the new hub4 and tested hard-wired speeds and nowhere near what was promised.  We have tried turning it off and leaving it for a bit to no avail. Upload speeds were on hub3 - realiably @34Mb and now is 18Mb.
On wifi it's even worse.
spgray
  • 2.39K
  • 139
  • 339
Problem sorter
Message 2 of 28
Re: Just installed the Hub4 and not getting promised speed
what speeds are you getting via ethernet on the hub4? down and up ?
My Broadband Ping - spgray
ozlaceuk
  • 12
Message 3 of 28
ozlaceuk
  • 12
Message 4 of 28
wired and wireless speeds below
spgray
  • 2.39K
  • 139
  • 339
Problem sorter
Message 5 of 28
your photo are being rejected, most likely because they have personal data in them (IP address maybe).
ozlaceuk
  • 12
Message 6 of 28
wireless speed onlywireless speed onlywired speed onlywired speed only
spgray
  • 2.39K
  • 139
  • 339
Problem sorter
Message 7 of 28
ok wired download speeds are showing bang on what you should be getting.
940Mbps is the maximum a 1Gbps ethernet port is capable of.
upload speed looks a little low though.
wifi download speed is probably, again, about right depending on the device you tested it on.
ozlaceuk
  • 12
Message 8 of 28
ok so again as I said the upload is slower than the hub3, hence my issue.
spgray
  • 2.39K
  • 139
  • 339
Problem sorter
Message 9 of 28
post your router stats, specifically the upstream stats.
the speedtest shows the line is capable of 1Gbps speeds, so it might be a config issue with the account, or a line issue.
ozlaceuk
  • 12
Message 10 of 28
hubby is also wondering if the resistor that was installed by the technician for the hub3 is an issue.
