Nasher1601
Issues
When is someone going to assist in the issues experienced due to the internet? It constantly drops out even if hard wired! This has been going on for weeks and is pretty embarrassing when working from home and get off from meetings due to it! Have tried contacting and can’t believe that you have no one that can actually call us and try to rectify the issue!
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Issues
Which Hub do you have ?
What is your contracted speed ?
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Issues
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Issues
Can you please
