hr100
  • 18
Issues with speed and internet dropping
Hello
Posting this for my parents. They have VM 200mb broadband.
They have an issue that if there is more than maybe 2 devices using the internet that the speed really slows down and its also dropping out. So if they are streaming something on sky then the internet is really slow during a skype call.
09/12/2020 19:54:31 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/12/2020 19:04:34 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/12/2020 19:04:10 critical Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/12/2020 19:04:10 critical Ranging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/12/2020 22:25:34 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/12/2020 22:25:10 critical Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/12/2020 22:25:10 critical Ranging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/12/2020 19:44:0 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/12/2020 19:43:36 critical Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/12/2020 19:43:36 critical Ranging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/12/2020 19:42:52 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/12/2020 17:55:6 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/12/2020 14:21:31 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/12/2020 14:21:7 critical Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/12/2020 14:21:7 critical Ranging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13310000009.440256 qam25
22670000008.440256 qam17
32750000008.438256 qam18
42830000008.940256 qam19
52910000008.940256 qam20
62990000009.140256 qam21
7307000000940256 qam22
8315000000940256 qam23
93230000009.140256 qam24
103710000009.840256 qam26
113790000009.640256 qam27
123870000009.640256 qam28
133950000009.840256 qam29
144030000009.640256 qam30
154110000009.540256 qam31
16419000000940256 qam32
174270000009.140256 qam33
18435000000940256 qam34
19443000000940256 qam35
20451000000940256 qam36
214590000008.840256 qam37
224670000008.540256 qam38
234750000008.340256 qam39
244830000008.140256 qam40
1Locked40.3241939
2Locked40.32945055
3Locked39.33685051
4Locked40.33395115
5Locked40.32195019
6Locked40.32011045
7Locked40.31951004
8Locked40.32421056
9Locked40.92211002
10Locked40.33741167
11Locked40.9432905
12Locked40.3367956
13Locked40.3582936
14Locked40.3590921
15Locked40.34401156
16Locked40.3378935
17Locked40.34731219
18Locked40.35831215
19Locked40.95941017
20Locked40.93991151
21Locked40.9387942
22Locked40.34312022
23Locked40.34351510
24Locked40.3328947
13940000039.5512064 qam2
22580000039.5512064 qam4
34620000039.8512064 qam1
43260000039.5512064 qam3
1ATDMA0060
2ATDMA005350
3ATDMA0020
4ATDMA00510
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Issues with speed and internet dropping
