  • 174
  • 14
Up to speed
Issues with latest hub firmware
Myself and a number of others have started to experience huge latency and speed issues since the latest update of SuperHub 3 software to v9.1.1811.401
https://community.virginmedia.com/t5/Gaming-Support/Poor-gaming-performance/td-p/4153124
https://community.virginmedia.com/t5/Gaming-Support/ps4-lag-spikes-from-mid-december/m-p/4172723
https://community.virginmedia.com/t5/Gaming-Support/Very-high-latency-packet-loss/m-p/4172624
This is the day my replacement Superhub (which was initially running the older software) upgraded to the new software at around 3:45 am:
4116f9c6684d0dfdede6c7f938f378d3c6f01eae-12-03-2020
While this isn't affecting everyone, it appears that this issue is widespread enough to require some attention from Virgin Media. Can someone from VM please respond to this thread to let us know if VM are aware of this, and what action is being taken? Is there any chance of getting software rolled back to the previous version?
Andy
  • 14.33K
  • 594
  • 1.38K
Re: Issues with latest hub firmware
Are you in router mode or modem mode?
Power off the hub for 5mins if you have your own router copy it WAN MAC to your PC NIC and only connect that to the hub and power on (unplug and replug the ethernet may be needed) see how your connection is for some hours.
  • 174
  • 14
Up to speed
In modem mode, as the thread I linked says (hopefully).
Done many tests with different equipment connected directly to the hub. Haven't gone as far as duplicating the MAC address though. All the tests I've done show a similar result. Running in 'router' mode isn't an option for me really, despite one of the support line bods trying to tell me that modem mode isn't really 'supported' by VM.
As I said above, I'm not alone in this, so troubleshooting my setup would seem a little pointless. While it's not everyone with this hub software that is seeing the issue, there are a number of people reporting it on here.
Andy
  • 174
  • 14
Up to speed
This thread seems to have been ignored by Virgin Media. Would appreciate some response.
Andy
