gambe1984
  • 5
Issues with Upload Throughput
Hello,
New to the forums but I thought id post here as the answers seem far more sensible than the support over the phone.
I am currently on the 350mb package, and at best the upload is hitting around 12mb tops on a speedtest, this has been as low 0.61mb at times. however that's not the only issue, whenever I upload any large amounts of data, a few gb's shall we say, it instantly falls over, no upload speed what so ever. Its almost as if the amount of data I am pushing is too much for the router/connection to handle and causing an over utilisation issue. I am not sure that's the issue, but I am struggling to understand what the issue is exactly.
I will post some logs though. Any assistance is appreciated.(Sorry had to post logs separately, kept saying it exceeding character limit, apologies)
gambe1984
  • 5
Re: Issues with Upload Throughput
267000000
Locked
Ranged Upstream Channel (Hz)
39400000
Locked
Provisioning State
Online
126700000012.140256 qam17
221900000011.538256 qam11
322700000011.540256 qam12
423500000011.540256 qam13
524300000011.440256 qam14
625100000011.438256 qam15
725900000011.838256 qam16
82750000001240256 qam18
928300000012.540256 qam19
1029100000012.540256 qam20
112990000001338256 qam21
123070000001340256 qam22
1331500000013.140256 qam23
1432300000013.540256 qam24
1533100000013.540256 qam25
1637100000013.940256 qam26
1737900000013.940256 qam27
183870000001440256 qam28
193950000001440256 qam29
204030000001440256 qam30
214110000001440256 qam31
2241900000013.940256 qam32
234270000001440256 qam33
2443500000013.938256 qam34
gambe1984
  • 5
1Locked40.350
2Locked38.950
3Locked40.340
4Locked40.340
5Locked40.350
6Locked38.910
7Locked38.650
8Locked40.900
9Locked40.350
10Locked40.350
11Locked38.940
12Locked40.360
13Locked40.350
14Locked40.300
15Locked40.300
16Locked40.900
17Locked40.340
18Locked40.3110
19Locked40.350
20Locked40.350
21Locked40.3130
22Locked40.300
23Locked40.330
24Locked38.960
gambe1984
  • 5
13940000041.5512032 qam2
22580000741.5512064 qam4
33260002441.5512064 qam3
44620000039.8512064 qam1
3ATDMA0000
4ATDMA0000
gambe1984
  • 5
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
fg87dsfd;kfoA,.iyewrkldJK
SFID28329
Max Traffic Rate402500089
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID28328
Max Traffic Rate38500089
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
14/12/2020 21:27:30noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/12/2020 21:27:24Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/12/2020 23:28:34criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/12/2020 20:24:31noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/12/2020 19:06:10noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/12/2020 19:06:10ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/12/2020 15:37:56criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/12/2020 07:06:10noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/12/2020 07:06:10ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/12/2020 23:18:18criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/12/2020 20:03:57noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/12/2020 19:06:10noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/12/2020 19:06:10ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/12/2020 10:18:27criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/12/2020 07:50:48noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/12/2020 07:50:48ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/01/1970 05:16:1ErrorToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/01/1970 05:13:48criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/1970 12:39:2ErrorToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/1970 12:38:43criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Anonymous
Not applicable
You will need an engineer out, as your downstream is on the high side.
