AdamLWestwood
Issues with Router
Hi All,
I've recently noticed a bit of lag in one of my games. Only started last night, but I was on earlier in the day and it was fine. After running some equipment checks and all coming back okay, I logged into the router page to look at the network log and noticed something strange. I read a similar post on here and that resulted in a technician visit.
I have a SuperHub 2 Router
My network log was displaying this:
Date
Time
Error Number
Error Description
Time Not Established
66050310
Auth Success - Web login successful.
66050300
Auth Fail - Web login failed.
68000406
TOD server unavailable
84020200
Lost MDD Timeout
84020200
Lost MDD Timeout
84020200
Lost MDD Timeout
84020200
Lost MDD Timeout
84020200
Lost MDD Timeout
84020200
Lost MDD Timeout
84020200
Lost MDD Timeout
84020200
Lost MDD Timeout
I've tried to get what information I can including some Downstream and Upstream data:
Lock Status
Channel ID
Frequency
Modulation
Rx Power
RxMER
Pre RS Errors
Post RS Errors
Locked
12
227000000 Hz
256 QAM
-0.1 dBmV
 34.2 dB
10848967
25154
Locked
9
203000000 Hz
256 QAM
-0.1 dBmV
 34.2 dB
17042447
519226
Locked
10
211000000 Hz
256 QAM
-0.5 dBmV
 33.8 dB
10636755
23283
Locked
11
219000000 Hz
256 QAM
-1.3 dBmV
 33.3 dB
16133551
3523157
Locked
13
235000000 Hz
256 QAM
0.1 dBmV
 34.8 dB
905683
2638
Locked
14
243000000 Hz
256 QAM
0.2 dBmV
 34.6 dB
557728
3052
Locked
15
251000000 Hz
256 QAM
0.4 dBmV
 34.6 dB
105549
5482
Locked
16
259000000 Hz
256 QAM
0.7 dBmV
 35.2 dB
214188
2759
Upstream:
Locked  9 60300000 HzATDMA4 3.5 dBmV 64QAM 6400000 Hz5120 Ksym/sec
Locked 10 53700000 HzATDMA4 3.5 dBmV 64QAM 6400000 Hz5120 Ksym/sec
Locked 11 46200000 HzATDMA4 3.0 dBmV 64QAM 6400000 Hz5120 Ksym/sec
Locked 12 39400000 HzATDMA4 3.0 dBmV 64QAM 6400000 Hz5120 Ksym/sec
I'm a bit concerned about the network log not recording times. Is my router on the way out?
jem101
  • 1.72K
  • 238
  • 802
Re: Issues with Router
Not recording the times is the least of your worries, the hub could be on it’s way out but I think it more likely that you have a cable fault. You’re going to need an engineer visit.
Zoie_P
  • 2.95K
  • 137
  • 236
Hi AdamLWestwood,
thanks for your post. I have checked your account and can see one of your frequencies are disabled this can cause congestion
thanks
Zoie
AdamLWestwood
Hi Zoie
Thanks for the reply. Would that be the WiFI frequencies? I have turned one off because I keep getting knocked off the Wi-Fi when upstairs. I found this solution to work. I only occasionally have to resign into Wi-Fi now.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Two of your Upstream Power Levels are a bit low.
Your Pre & Post RS Error counts are very high.
In an ideal world they would be at zero and stay there. To zero them can you reboot the Hub using this method and then keep an eye on the counts.
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then check the counts again in an hour or so.
Upstream:
Lock Status
Channel ID
Frequency
Modulation
Rx Power
RxMER
Pre RS Errors
Post RS Errors
Locked
12
227000000 Hz
256 QAM
-0.1 dBmV
 34.2 dB
10848967
25154
Locked
9
203000000 Hz
256 QAM
-0.1 dBmV
 34.2 dB
17042447
519226
Locked
10
211000000 Hz
256 QAM
-0.5 dBmV
 33.8 dB
10636755
23283
Locked
11
219000000 Hz
256 QAM
-1.3 dBmV
 33.3 dB
16133551
3523157
Locked
13
235000000 Hz
256 QAM
0.1 dBmV
 34.8 dB
905683
2638
Locked
14
243000000 Hz
256 QAM
0.2 dBmV
 34.6 dB
557728
3052
Locked
15
251000000 Hz
256 QAM
0.4 dBmV
 34.6 dB
105549
5482
Locked
16
259000000 Hz
256 QAM
0.7 dBmV
 35.2 dB
214188
2759
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
