alphaomega16
  • 212
  • 11
Message 1 of 1
Issues since VM UK wide issues
I have noticed a subtle change in day to day internet browsing as well as gaming, star trek online for example for years was ~ a 14 hop journey but after the issues with VM its nearly doubled, seen slight delays in sites the last day or two and today I noticed this bump when viewing my line monitor from TBB.
Live graph here
https://www.thinkbroadband.com/broadband/monitoring/quality/share/0ae692939d1822940f80da9ad3fd98a3f9...
Issues started here, it pretty much just instantly doubled latency
https://www.thinkbroadband.com/broadband/monitoring/quality/share/074fe51a31c221b6c63e708e11cc2a76d6...
You will also see getting some red spikes after the VERY unusual never seen before steep step up, not a spike its just the new baseline now.
The days beforehand were all as you see before the step up, I have had issues with Star Trek Online in particular for a while but with the routing changes making things worse maybe its not all down to them.
The jump you see happened before I even woke up (yeah I know, its afternoon but late to bed late to rise)
Are there still ongoing issues?
Edit
Can't seem to reply to my own inquiry but these are power levels currently
Downstream  DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz)139000000147000000155000000163000000171000000179000000187000000195000000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)LockedLockedLockedLockedLockedLockedLockedLocked
Channel ID12345678
Modulation256QAM256QAM256QAM256QAM256QAM256QAM256QAM256QAM
Symbol Rate (Msym/sec)6.9520006.9520006.9520006.9520006.9520006.9520006.9520006.952000
Interleave DepthI=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)3.393.363.333.373.063.223.183.21
RxMER (dB)37.3637.9437.3637.6438.2638.2638.2638.26
Pre RS Errors
615144707411650411331344378
Post RS Errors
301301295286288284313335
Upstream  US-1 US-2 US-3 US-4
Channel Type2.02.02.02.0
Channel ID2134
Frequency (Hz)53700000603000004620000039400000
Ranging StatusSuccessSuccessSuccessSuccess
Modulation64QAM64QAM64QAM64QAM
Symbol Rate (Sym/sec)5120000512000051200005120000
Mini-Slot Size2222
Power Level (dBmV)46.2547.0045.5045.25
T1 Timeouts0000
T2 Timeouts0000
T3 Timeouts1000
T4 Timeouts0000
