Suraj1
  • 5
Issue with Speeds on Hub 4 and stuck on solid green light
HI,
My Hub 4 has been stuck on a solid green light for a couple of days. I presume this is a software update but surely it cannot take forever to download.
Could this be looked into?
Also could someone confirm if the following power levels are within tolerance? Recently my download speed has been going down to 9-10mb but upload has been stable on 50mb.
below are the logs from the router.
3.0 Downstream channels
37523000000-5.09999838.983261QAM25637
81950000003.09999840.946209QAM2568
92030000002.79999940.946209QAM2569
102110000002.50000040.366287QAM25610
112190000002.29999940.946209QAM25611
122270000002.00000040.946209QAM25612
132350000001.70000140.366287QAM25613
142430000001.09999840.366287QAM25614
152510000000.50000040.946209QAM25615
16259000000-0.20000140.946209QAM25616
172670000001.00000040.366287QAM25617
182750000001.29999940.366287QAM25618
192830000000.50000040.366287QAM25619
20291000000-0.20000140.366287QAM25620
21299000000-0.90000240.946209QAM25621
22307000000-0.79999940.366287QAM25622
23315000000-1.00000040.946209QAM25623
24323000000-1.09999840.366287QAM25624
25331000000-1.90000240.366287QAM25625
26339000000-2.00000040.366287QAM25626
27347000000-2.09999840.366287QAM25627
28355000000-2.70000140.366287QAM25628
29363000000-3.00000038.983261QAM25629
30371000000-4.70000138.605377QAM25630
31379000000-4.50000038.983261QAM25631
32387000000-4.29999938.983261QAM25632
33395000000-4.59999838.983261QAM25633
34403000000-4.90000238.983261QAM25634
35411000000-5.00000038.605377QAM25635
36419000000-4.70000138.605377QAM25636
38531000000-5.20000138.983261QAM25638
3.1 Downstream channels
159964K1840QAM4096424
159Locked41-4.212140558360
3.0 Upstream channels
13010000040.0205995120 KSym/sec64QAM4
22360000039.5205995120 KSym/sec64QAM5
33660000041.0205995120 KSym/sec64QAM3
44310000041.5205995120 KSym/sec64QAM2
54960000042.0205995120 KSym/sec64QAM1
NinjaMeerkat
  • 460
  • 20
  • 92
Fibre optic
Re: Issue with Speeds on Hub 4 and stuck on solid green light
A solid green light on a hub4 indicates it is in modem mode.
  • 13.91K
  • 1.08K
  • 2.82K
Downstream is on the low side, but within spec. Please could we have the remaking stats are they are the important bit.
