jakeyworth
  • 8
Message 1 of 5
Is the speed acceptable
I've never been blessed with a decent download speed throughout my virgin experience from upgrade to upgrade but for what i required at the time it suited. However asking around it seemed others were having better download speeds than me and now I'm paying more and more for the service I'm going to asking more from virgin service.
Having upgraded from 100 to 200M recently my download was still around the 100M value however its now hitting 75-85Mbps peaking at 91 with with drops as low as 45Mbps the upload is static at 20Mbps.
With the amount of expertise on here are these figures acceptable for a 200M service.
many thanks for any feed back
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 2 of 5
Re: Is the speed acceptable
How are you testing with Wi-Fi or ethernet connected device ?
The speeds you have stated are indicative of a Network Interface Card (NIC) set at 10/100, it needs to be at 100/1000.
You check this in the settings of your device.
jakeyworth
  • 8
Message 3 of 5
Thanks Mike
my Nic is 10/100 on a laptop and as you have indicated this is the reason for the readings im getting.
thanks
Buffer6
  • 9.71K
  • 88
  • 605
Hero
Message 4 of 5
it means your equipment won't go any faster than 100Mbps usually slower.  To take advantage of speeds more than 100Mbps
you need to be using a Gigabit card set to Auto-negotiate. if you have a USB3 port you can buy on Amazon an external Gigabit card which
will allow you to get the faster speeds https://www.amazon.co.uk/s?k=USB+3+external+Gigabit+NIC&ref=nb_sb_noss
jakeyworth
  • 8
Message 5 of 5
Many thanks buffer6 ill look into that. brill
