airwot4
  • 9
Message 1 of 12
Is rain causing my BB issues?
Generally speaking my BB is fairly reliable. I rarely get my 200Mb download speeds but it's normally in the 100+ range.
Today it's been hovering around 15Mb so I decided to restart my router. That was a mistake, cue my internet being down for 90 minutes whilst it couldn't re-establish an upstream connection. I booked in an engineer but they won't be here until the middle of next week.
I realise that today is a heavy rain day and I seem to recall wondering before if rain could be causing issues with my connection. Perhaps it's a coincidence, perhaps everybody is inside streaming videos and causing contention. But throughout this year my speeds have been pretty okay in CF14.
Will the engineer laugh my out the door when I start to blame the weather? Or is there at least some indication of an issue in the below stats that they might be able to investigate?
happywithmy350
  • 1.02K
  • 46
  • 137
Well-informed
Message 2 of 12
Re: Is rain causing my BB issues?
No VM services run underground.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 3 of 12
There is every possibility that your BB is affected by rain.
In your case it may have something to do with your Upstream Channels running right on the max of 51.0dBmv.
airwot4
  • 9
Message 4 of 12
My BQM
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 12
@airwot4 wrote:
My BQM
That BQM looks nigh on perfect for a VM connection.
Until you see the dropped packets at the top of the graph.
Probably to do with your Upstream power levels.
You need an engineer to put them to a better level.
airwot4
  • 9
Message 6 of 12
I have an ongoing issue with an online game and the game host got me to run some tests. They said that the problem was due to be getting a lot of packet loss.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 12
More than likely.
Did you get as far as the second sentence in Post # 5
happywithmy350
  • 1.02K
  • 46
  • 137
Well-informed
Message 8 of 12
The best answer is from someone who does not even understand how it works.
Winner
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 9 of 12
Winner
Is that a constructive or sarcastic comment ?
jhuk
  • 3.03K
  • 52
  • 290
Problem sorter
Message 10 of 12
In the past I have seen water coming in cables outside windows and running down the inner core to inside the home and causing issue with TV/BB with friends family members and though the main cables and pots are under ground as someone stated the here they fill up with water and the connectors can let water in if not water tight any longer and corrode and this effects your power levels.
VM now put these things above ground where they can but I am told my area as ex TW-BY will not be anywhere.
