rolash
  • 8
Message 1 of 10
Irregular speed and ping
Previously with Virgin all service have been fine, however over the past year or so our speeds have been jumping around from below 100mbps to the advertised 350mbps, as well as high spiking ping which makes gaming, streaming and voip impossible at times.
Of course due to the Covid 19 pandemic a drop in service was to be expected with a larger proportion of people now working from home. however this doesn't explain the prior changes to service or the fact that no utilization fixes seem to have been put in place.
When I last attempted to use the customer service phoneline back around August 2020, we were sent a replacement Hub 3 modem which didn't really help. I also had a phone call arranged with a higher level phone technician who never ended up calling us.
Numerous issues have been told to us but each time the estimated date of completion for the remedy work is reached, the time is extended by days, weeks, and months. Some of the issues given were  a faulty Hub 3, signal issues, utilization issues, congestion issues, and network issues. Each time the phone rep was asked for further details or work tickets they could not be provided.
rolash
  • 8
Message 2 of 10
Re: Irregular speed and ping
Attached is a thinkbroadband quality monitor
https://www.thinkbroadband.com/broadband/monitoring/quality/share/1501160a27e71c36e1eef282a6114a7be7ea3c80
Router information
1402750000-3.240256 qam30
22027500000.440256 qam9
3210750000038256 qam10
4218750000-0.240256 qam11
5226750000-0.738256 qam12
6234750000-1.238256 qam13
7242750000-1.440256 qam14
8250750000-1.738256 qam15
9258750000-1.740256 qam16
10266750000-1.738256 qam17
11274750000-1.740256 qam18
12282750000-1.740256 qam19
13290750000-1.738256 qam20
14298750000-1.538256 qam21
15306750000-1.538256 qam22
16314750000-1.540256 qam23
17322750000-238256 qam24
18330750000-1.940256 qam25
19370750000-2.940256 qam26
20378750000-340256 qam27
21386750000-3.438256 qam28
22394750000-340256 qam29
23410750000-338256 qam31
24418750000-3.738256 qam32
1Locked40.311030
2Locked40.3385541772
3Locked38.9319351194
4Locked40.328640988
5Locked38.925776796
6Locked38.922391610
7Locked40.321207546
8Locked38.918828440
9Locked40.314882282
10Locked38.913942260
11Locked40.311482192
12Locked40.39657153
13Locked38.98530122
14Locked38.6707390
15Locked38.9584060
16Locked40.3512349
17Locked38.9438829
18Locked40.3388318
19Locked40.317661
20Locked40.914240
21Locked38.916100
22Locked40.311160
23Locked38.99100
24Locked38.910250
 [MOD EDIT: Personal and private information has been removed from this post. Please do not post personal or private information in your public posts. Please review the Forum Guidelines]
rolash
  • 8
Message 3 of 10
12579992736512032 qam5
23260000038.5512064 qam4
33940002440.5512064 qam3
44619995240.5512064 qam2
3ATDMA0000
4ATDMA0000
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 10
Is it a Wi-Fi problem or ethernet problem or both ?
rolash
  • 8
Message 5 of 10
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
v9873254k;fg87dsfd;kfoA,.
SFID14062
Max Traffic Rate402500089
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID16626
Max Traffic Rate38500089
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
rolash
  • 8
Message 6 of 10
this is both wifi and ethernet
rolash
  • 8
Message 7 of 10
04/01/2021 15:55:57noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2021 19:08:52criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2021 08:55:37noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2021 08:55:37ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2020 02:56:20criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2020 02:26:18noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2020 02:26:18ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/12/2020 05:39:36criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/12/2020 22:04:13Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/12/2020 08:43:52criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/12/2020 02:54:53noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/12/2020 02:54:53ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/12/2020 02:54:50ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/12/2020 11:08:30criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2020 09:17:37Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2020 09:17:32criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2020 09:17:32Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2020 09:17:25Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2020 09:17:25criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 8 of 10
Your >> BQM << is certainly showing a utilisation problem.
You need to go back into the speed test table and delete your WAN IP Address from every line.
TBH you would be as well deleting the whole table.
rolash
  • 8
Message 9 of 10
The posted thinkbroadband info is from my PC which is connected to the Hub3 via a cat6 cable
rolash
  • 8
Message 10 of 10
What does this mean in terms of potential improvements?
I have removed the table under your recommendation
