Bigbarloo
  • 5
Internet upload speed really slow
  • Hello, I was watching Netflix the other day and it kept stopping saying error, my Internet is always going off every other day like it's trying to reconnect or something, what's more annoying is I play xbox a lot and it keeps lagging during play, I use ethernet cable, I did a speed test I'm on m200 Internet package I did 4 tests through xbox which the download speed varied from 200 - 79mbps which should be fine but the upload was shocking between 1.54 - 6.78 mbps I should be getting between 15-20 upload speeds, it's saying no problem in the area other than TV on demand but clearly not. Area is Sheffield postcode S2.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Internet upload speed really slow
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
