aaronshowell09
Internet speed
Hello there
My son's X box is slow, I've checked out the speed and it reads only at download speed 31.67mbps upload speed at8.09mbps and wireless strength at 76%. I'm on the M100 package with the average 108mbps. I've scanned the strength on the connect app and it says all good
carl_pearce
  • 1.78K
  • 114
  • 378
Super solver
Re: Internet speed
@aaronshowell09 wrote:
Hello there
Login to your HUB and check the 'Connected Devices' section to see the speed the Xbox is connected at.
  • 6.82K
  • 593
  • 1.79K
Re: Internet speed
Consoles are not a good tool for measuring speeds and also VM do not guarantee wifi speeds.
You need to test a direct wired Cat 6a connection to the Hub from a gigabit capable device.   It would be better to hard wire the XBox in any case.
Chris_W1
  • 6.57K
  • 276
  • 442
Re: Internet speed
Hi aaronshowell09, thanks for the message. Would you be able to do a direct to the hub speed test via a wired connection please. This will need to be done via a PC or Laptop. Please do this by visiting speedtest.net. ^Chris
