Foskett19
Message 1 of 5
Internet speed
Hi guys.
hoping someone can help me as virgin haven’t been too helpful. My internet speed is the 350M that I pay for. However on my Wi-Fi when playing pc it’s always lagging, I’m told my sons Xbox lags random points in different games and when I have an update to do on the PC it does it at about 7MBPS? I am connected using TP link box’s so one downstairs plugged into Wi-Fi and one into back of pc. Any advice ?
Tags (3)
  • 6.08K
  • 511
  • 1.57K
Message 2 of 5
Re: Internet speed
Power line adapters are not great. Especially when the circuits are on different floors. Personally I wouldn’t use them, but would cable to the Hub.
Foskett19
Message 3 of 5
Re: Internet speed
Hi thanks for the reply.
the issue I face is my computer is upstairs and my Wi-Fi box is in the lounge. So I’m not sure how I could do it with an Ethernet due to the distance between!
  • 6.08K
  • 511
  • 1.57K
Message 4 of 5
Re: Internet speed
Maximum Cat 6a cable run is 100 metres.  Yes, sometimes cabling can be a pain, but you can run externally.  I've done this in the past for a family member by running a cable out the wall via the VM incoming hole, up the guttering (cable tie behind) and into the roof space. From there just drop down into the bedroom to a switch, or Wireless Access Point (preferably with extra ports).  If you are competent with DIY, it's an easy win.
Hayley_S
  • 3.9K
  • 129
  • 255
Message 5 of 5
Re: Internet speed
Hello @Foskett19,
Welcome to the community page, thanks for posting.
I am sorry for the issues you have been having with your speeds.
When gaming or working on a work laptop, we do recommend you try using your wired connection as this has stable speeds. Wi-Fi is not reliable for this kind of usage.
Many thanks,
Hayley
