Patricia161
  • 10
Internet speed
Engineer connected my phones to modem as landline was crackling because of outside fault ever since my iPhones and iPads can’t connect to internet as speed to slow but every other device is running ok could the phones be interfering with my devices as this has happened as soon as engineer did this
nodrogd
  • 16.82K
  • 1.97K
  • 4.08K
Re: Internet speed
The hub based 21CV lines do not use the internet connection. They use a separate radio connection down the cable to the exchange, so nothing on your internet connection or WiFi should be affected.
VM BB TV Landline PAYG mobile. Freeview/Freesat HD, Tesco Mobile. Customer since 1993
Zak_M
  • 4.44K
  • 259
  • 421
Re: Internet speed
Good morning @Patricia161
Welcome to the forums and thank you for taking the time to post.
I am sorry to hear that you have had some issues with your services.
Please could you pin hole reset the hub and let me know if there are any improvements on the connecting your iPad and iPhone
Kind regards,
Zak_M
Patricia161
  • 10
Re: Internet speed
I had to take off my devices upstairs to be able to connect to Internet can’t understand why it won’t take all my devices as it has always done this before and now I am updating to 350 from 100 it is running slowly so apps won’t connect
  • 3.2K
  • 250
  • 698
Re: Internet speed
Why are you upgrading to a higher speed if you are having problems with your VM circuit at present.  You should get this fixed first before upgrading.
Patricia161
  • 10
Re: Internet speed
Problems started when I upgraded no problems before but everything sorted now thanks
