Chrisfisher86
  • 5
Message 1 of 7
Internet speed
Been sent here from Twitter, was asked to post upload and download speeds and someone would help me.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 2 of 7
Re: Internet speed
A bit more information is required, please post the following ...
Please do this before posting the Hub Data
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 3 of 7
Re: Internet speed
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Please do not use screen shots.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
Chrisfisher86
  • 5
Message 4 of 7
Re: Internet speed
Chrisfisher86
  • 5
Message 5 of 7
Re: Internet speed
1418750000-9.238256 qam32
2202750000-6.938256 qam9
3210750000-738256 qam10
4218750000-738256 qam11
5226750000-7.238256 qam12
6234750000-7.538256 qam13
7242750000-7.240256 qam14
8250750000-738256 qam15
9258750000-7.438256 qam16
10266750000-7.438256 qam17
11274750000-7.738256 qam18
12282750000-7.938256 qam19
13290750000-7.738256 qam20
14298750000-7.538256 qam21
15306750000-7.738256 qam22
16314750000-7.738256 qam23
17322750000-7.738256 qam24
18330750000-8.438256 qam25
19370750000-8.538256 qam26
20378750000-8.938256 qam27
21386750000-9.238256 qam28
22394750000-9.538256 qam29
23402750000-9.738256 qam30
24410750000-9.538256 qam31
1Locked38.91039866
2Locked38.99102598
3Locked38.98112488
4Locked38.912262550
5Locked38.97372561
6Locked38.913592961
7Locked40.340182587
8Locked38.68532281
9Locked38.96802285
10Locked38.96382289
11Locked38.95842156
12Locked38.95962315
13Locked38.97812215
14Locked38.673232633
15Locked38.964322528
16Locked38.96212503
17Locked38.95511999
18Locked38.94831346
19Locked38.95051498
20Locked38.65201642
21Locked38.969926
22Locked38.679802
23Locked38.91091572
24Locked38.9591490
Chrisfisher86
  • 5
Message 6 of 7
Re: Internet speed
16030000057512064 qam1
1ATDMA0020
Chrisfisher86
  • 5
Message 7 of 7
Re: Internet speed
