Alan3842
  • 16
Message 1 of 9
Internet speed
I am in area 21 and over the past couple of days, my internet speed has reduced from around 100Mbps to 20Mbps.  I’ve tried resetting the router.  Any thoughts?
Anonymous
Not applicable
Message 2 of 9
Re: Internet speed
area codes are not geographic. area 21 can cover most of the UK 😉
Alan3842
  • 16
Message 3 of 9
Re: Internet speed
OK I’m in SE9.
Anonymous
Not applicable
Message 4 of 9
Re: Internet speed
how are you testing the speed. Wired or wireless?
Does the https://my.virginmedia.com/faults/service-status list any faults?
Alan3842
  • 16
Message 5 of 9
Re: Internet speed
Wired and wireless.
No.
Alan3842
  • 16
Message 6 of 9
Re: Internet speed
I have just checked the wired connection and it's OK.  However, the wireless connections to three devices are at significantly reduced speeds, by varying amounts.
Anonymous
Not applicable
Message 7 of 9
Re: Internet speed
if the wired connection is OK then the VM connection is working as expected.
The VM hubs are known to be weak on wifi. You can try a few things but the best thing you can do is get your own better router.
Check you are using a 5ghz 802.11ac device
Split the 2.4ghx and 5ghz band SSID and make sure you connect to the 5ghz one
disable smart wifi on the hub
Alan3842
  • 16
Message 8 of 9
Re: Internet speed
Thanks I’ll try your suggestions.  I’m reluctant to buy a new (better) router but it might come to that.
Alan3842
  • 16
Message 9 of 9
Re: Internet speed
For some reason 5G was disabled.  I've enabled it and all's good now.  Thanks very much for your help 👍
