W033a
  • 9
Message 1 of 5
Internet speed
Has anyone got the internet speed and Reliability of what they payed for ?
im on m500 and average speed is about 60mbps
the connection freezes from time to time,
we find that is quicker to hotspot to our phone 4g than use home WiFi
engineer been out check all cables checked router
direct Ethernet from router to 2020 Alienware laptop comes out at 60mbps
we found bt 40mbps was better more Reliable that vm
calling up to try and get this resolved is a joke, 45min waiting then get cut off tried 3 time give up,
this in Sheffield area s5
have you had same problem what fixed it for you
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 5
Re: Internet speed
How are you connecting your device, Wi-Fi or ethernet cable ?
W033a
  • 9
Message 3 of 5
Re: Internet speed
Ethernet cable direct from laptop to router
work from home
phones just 2 on  WiFi
Question was any one having same problem, buy 500 get 60
if they have fix or resolve the problem,
wifi will always be slower, direct connections should be 90%
months ago we saw 300 to 410 for 2/3 weeks
new laptops have been bought, Ethernet cable, even the company who I work for sent there engineer out and checked work laptop cable and router settings and all wire to router, his answer was vm exchange or cap, he check and tested and advise fault not in property
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 5
Re: Internet speed
The ethernet speed that you are reporting is indicative of a Network Interface Card (NIC) set at 100/100 instead of 100/1000 but your company engineer has stated that the problem is a supply problem so who am I to argue.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Hub 3 When the page appears DO NOT LOG IN but click ‘Check Router Status’.
W033a
  • 9
Message 5 of 5
Re: Internet speed
Thanks for your reply
I will log over 72 hours starting later to day
