elaineh
  • 11
Message 1 of 16
Internet speed slow
Hi, I upgraded my internet to M350 due to working from home. I don't seem to be getting anywhere near the speeds I should have. I understand that by connecting to the VPN it can slow. But when testing speeds on my own laptop through a wired connection the maximum speed I can get is about 120mbps but regularly around 30mbps. I'm not technical at all, any help I can get will be great, thank you
JitteryPinger
  • 1.86K
  • 207
  • 389
Super solver
Message 2 of 16
Re: Internet speed slow
Are these speed tests via the VPN mentioned?
I know it sounds cliche to say it but the VPN will reduce speeds and make them unvariable.
If I've helped let me know 🙂
10 year's managing 9 Virgin Media accounts, and things never got any better, closed last 4 accounts since January 2021 :L
I give 'my' experience to help where possible.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 3 of 16
With VPN disabled.
hat speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 16
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 16
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
elaineh
  • 11
Message 6 of 16
Hi, sorry for such a slow reply
Just going through everything now that you've requested.
Sam Knows stats
Latency
29.6 ms
Jitter
14.7 ms
Download
31.5 Mbps
Upload
37.8 Mbps
the speed showing on connected devices is 1000mbps
elaineh
  • 11
Message 7 of 16
My BQM
elaineh
  • 11
Message 8 of 16
Router status
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
13310000006.543256 qam25
2203000000540256 qam9
32110000004.940256 qam10
42190000004.940256 qam11
5227000000540256 qam12
6235000000540256 qam13
7243000000540256 qam14
82510000005.140256 qam15
92590000005.440256 qam16
102670000005.540256 qam17
112750000005.440256 qam18
122830000005.440256 qam19
132910000005.540256 qam20
142990000006.340256 qam21
153070000006.340256 qam22
163150000006.340256 qam23
173230000006.440256 qam24
183390000006.540256 qam26
193470000006.540256 qam27
203550000006.140256 qam28
213630000006.140256 qam29
22371000000640256 qam30
233790000006.440256 qam31
243870000006.640256 qam32
1Locked43.340
2Locked40.9170
3Locked40.950
4Locked40.350
5Locked40.950
6Locked40.940
7Locked40.950
8Locked40.950
9Locked40.360
10Locked40.950
11Locked40.950
12Locked40.940
13Locked40.950
14Locked40.340
15Locked40.950
16Locked40.960
17Locked40.370
18Locked40.970
19Locked40.960
20Locked40.950
21Locked40.940
22Locked40.960
23Locked40.960
24Locked40.900
elaineh
  • 11
Message 9 of 16
16030002642.3512064 qam1
23940000042.3512064 qam4
34620001742.3512064 qam3
45369997642.3512064 qam2
3ATDMA0000
4ATDMA0000
elaineh
  • 11
Message 10 of 16
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
dsfd;kfoA,.iyewrkldJKDHSUBsgv
SFID12774
Max Traffic Rate402500089
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID12773
Max Traffic Rate38500089
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
