Gemma987654321
  • 5
Settling in
Message 1 of 9
Internet speed slow and upload speed at 0.2mbps?
Hi, I hope someone can help.
I upgraded to virgin as I now work via Zoom and thought the extra speed would be great but since joining its actually been worse than my old 'standard" broadband. IMy VIrgin speed is meant to be around 100mb download/10mb upload and I often just get 10/20mbps download and 0.2mb upload. It seems to be getting worse and I'm losing work (I teach online) because of it. Any help very much appreciated. Thanks, Gemma.
Ps. Ive done all the checks, restarted and factory reset the router, done speed tests on different devices, tested over wifi and ethernet cable and its still the same.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 9
Re: Internet speed slow and upload speed at 0.2mbps?
Can you please
Gemma987654321
  • 5
Settling in
Message 3 of 9
Thank you for your quick reply Mike. Much appreciated.
11390000000.740256 qam1
21470000000.540256 qam2
31550000001.240256 qam3
41630000000.740256 qam4
51710000000.740256 qam5
61790000001.240256 qam6
71870000001.240256 qam7
81950000001.240256 qam8
92030000001.240256 qam9
102110000001.540256 qam10
112190000001.240256 qam11
12227000000140256 qam12
132350000001.440256 qam13
142430000001.440256 qam14
15251000000140256 qam15
162590000000.740256 qam16
17267000000140256 qam17
182750000001.440256 qam18
192830000001.240256 qam19
202910000001.240256 qam20
21299000000140256 qam21
223070000001.540256 qam22
233150000001.240256 qam23
24323000000140256 qam24
1Locked40.9342866120408
2Locked40.339241856795
3Locked40.9328508127390
4Locked40.3328702152426
5Locked40.345221811211
6Locked40.9314105149600
7Locked40.3293132126310
8Locked40.92977879001
9Locked40.32557678843
10Locked40.31911268078
11Locked40.91668767545
12Locked40.91554487744
13Locked40.31466697676
14Locked40.91344407115
15Locked40.31204786351
16Locked40.31727066847
17Locked40.32507577143
18Locked40.32695786825
19Locked40.32421526498
20Locked40.91804365515
21Locked40.31698826370
22Locked40.91491374894
23Locked40.31613433785
24Locked40.31252332240
Gemma987654321
  • 5
Settling in
Message 4 of 9
1603000005.1512064 qam1
2462000005.1512064 qam3
3537000005.1512064 qam2
4394000005.075512064 qam4
3ATDMA0000
4ATDMA0000
Gemma987654321
  • 5
Settling in
Message 5 of 9
23/10/2020 13:07:11Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 13:03:5noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 13:01:43Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 12:27:28Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 12:21:45criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 12:20:11Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 12:16:24criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 12:09:42Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 12:09:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 12:09:31Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 12:03:56criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 12:00:45noticeSW download Successful - Via Config file
23/10/2020 11:59:8criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 11:58:46noticeSW Download INIT - Via Config file
01/01/1970 00:02:25criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 11:52:24Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 11:52:3criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 10:46:21Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 10:45:58criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 10:31:21Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 9
Three of your Upstream Power Levels are too high and the other one is maxed out.
This will need an engineer to put right.
You can either phone in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
Gemma987654321
  • 5
Settling in
Message 7 of 9
Thank you again. Do You know which phone number to use? Ive just googled it and it keeps taking me in circles.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 8 of 9
Text service on 07533051809
150 from Virgin landline.
0345 454 1111 from any other UK  phone.
Ryan_N
  • 2.09K
  • 104
  • 188
Message 9 of 9
Hi Gemma987654321,
Thank you for your post and welcome to the forums.
Sorry to see you've been having an issue here and thank you for following @MikeRobbo advice. I can see that a tech was booked on the account, can you confirm if that did take place?
Cheers.
Ryan_N - Forum Team - https://community.virginmedia.com/t5/custom/page/page-id/WelcomeGoodFolk
