Message 1 of 5
Internet speed issue
Hey all
Seen the countless threads but not sure if mine is the same issue.
I noticed alot of buffering so decided to do a speed test using ookla
What I've noticed is I cannot get more the 2mbps download but....
If I factory reset or just reboot router then immediately after reboot and connection becomes active I get returned speeds of 150+ mbps
I'm on a 300 or 350 package
Speed test 1
https://imgur.com/a/cvHxPbm
Speed test 2
https://imgur.com/a/U8D7wCl
 any ideas why after less than a minute I'm capped at 2mbps?
Edit: just to add I've not had any issues like this before and only noticed yesterday evening it started becoming real slow...
  • 12.44K
  • 859
  • 3.72K
Message 2 of 5
Re: Internet speed issue
You need to provide a speedtest from a device with a known 1Gbps NIC wired to the HUB with WiFi off to see what you are ACTUALLY getting
Message 3 of 5
Doesn't matter the device
My phones always been able to top out the ookla speed test at 240-300mbps
My pc hard wired straight to router set in modem mode still only provides 4mbps.
Only way this goes up no matter the device is after a reboot of the router.... Then withing less than 3 minutes I'm down to the 2-4mbps
Theres no errors on router network status and all downstream up streams look comparable to someone else's post who was confirmed all OK....
  • 6
Message 4 of 5
same thing here https://imgur.com/WXm58E7
hope it's an issue on their end and not both our routers coincidentally having the same problem at the same time lol
  • 5
Message 5 of 5
Well,  I contacted virgin through their text service and for a pretty prompt response. I was then contacted by phone and was told they didn't know. Think they've now given up. Awful company.
