Hi @matmad
I'm afraid your second speedtest picture was rejected as it showed your IP address.
You should post your router stats here for the learned members to check what the problem is and offer assistance.
In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) and hit return.
Don't login, instead below there click on Check Router Status
From the Router Status page copy/paste 3 FULL sets of data as text onto here – from the Downstream, Upstream, & Network Logs pages.
You will have to click on "Post" twice when doing the Network Logs as they contain your MAC address, the MAC address will be redacted by the system and then that post will go through.
You could also set up a BQM monitor at thinkbroadband.com - this will give you an insight into what is happening with the signal at the other side of the Hub, and also help show up any issues. It will take a few hours to get any kind of trend showing although you can post the link straight away.
In the URL box paste the link you copied and then click OK.
DaveI don't work for Virgin Media.
The do's and don'ts. Keep the community welcoming for all.
Follow the house rules The Service you do for others is the rent you pay for your room here on Earth - Muhammad AliLove, love and love, forever - Pele
