canioking
  • 19
Message 1 of 17
Internet keeps falling to silly low speeds after reboot.
1483000000-7.438256 qam30
2187000000-3.940256 qam7
3195000000-4.240256 qam8
4203000000-4.540256 qam9
5211000000-4.540256 qam10
6219000000-4.740256 qam11
7227000000-4.740256 qam12
8235000000-5.240256 qam13
9243000000-5.440256 qam14
10251000000-5.540256 qam15
11259000000-5.740256 qam16
12267000000-5.740256 qam17
13275000000-640256 qam18
14283000000-640256 qam19
15291000000-640256 qam20
16299000000-640256 qam21
17307000000-6.240256 qam22
18315000000-6.938256 qam23
19323000000-7.238256 qam24
20443000000-7.538256 qam25
21451000000-7.238256 qam26
22459000000-7.738256 qam27
23467000000-7.538256 qam28
24475000000-7.438256 qam29
1Locked38.621880
2Locked40.9220
3Locked40.9100
4Locked40.91730
5Locked40.9130
6Locked40.3290
7Locked40.3280
8Locked40.3420
9Locked40.3260
10Locked40.9300
11Locked40.9350
12Locked40.3410
13Locked40.3440
14Locked40.9670
15Locked40.3730
16Locked40.3780
17Locked40.31160
18Locked38.61370
19Locked38.91730
20Locked38.912190
21Locked38.910270
22Locked38.911210
23Locked38.912900
24Locked38.61328
0
canioking
  • 19
Message 2 of 17
Re: Internet keeps falling to silly low speeds after reboot.
1461999475.1512064 qam1
2257999934.8512064 qam4
3326000074.9512064 qam3
4394000024.95512064 qam2
3ATDMA0000
4ATDMA0000
canioking
  • 19
Message 3 of 17
30/12/2019 15:44:55noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsl10016u-b.cm modified;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
30/12/2019 20:13:17criticalNo Ranging Response received - T3 time-out;CM-MAC=CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
31/12/2019 18:39:1Warning!Lost MDD Timeout;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
31/12/2019 21:34:9criticalNo Ranging Response received - T3 time-out;CM-MAC=;CMTS-MAC=CM-QOS=1.1;CM-VER=3.0;
31/12/2019 21:42:50Warning!
canioking
  • 19
Message 4 of 17
My internet has gone crazy since new years eve, guessed it was just everybody on the internet was there problem but just has not got any better . Everything is so slow , buffering or timing out . Playstation shows download of nearly 100mpbs when reboot but next test its down to 1mbps. The hangs around under 10mpbs. Any help ?
  • 22.41K
  • 2.4K
  • 3.99K
Message 5 of 17
The recommended lower limit for downstream power levels/channel is -6dBmV - so many of yours are below that and the rest close to it. Your upstream power levels are on the high side too (albeit just in range).
You need a technician visit to adjust the power levels. Either call it in as a fault (might be quicker) or wait for a day or two on here when a VM Forum Team member should offer to arrange that for you
canioking
  • 19
Message 6 of 17
Well that's a waste of an hour of my life , rang 150 to report fault explaining what had been said in previous message . Only to be told that's rubbish , people post anything in the places was he's reply (meaning virgin own community pages ). When i then mentioned my virgin HUB 3.0 status report with many critical faults and warnings he replied never heard of it .... Refused to book technician or allow me to speak to any senior member of staff. Now got to wait for a call back tomorrow as everything is right at his end. Thou i have very slow internet and test that give far apart results . I await a Virgin response ...........
canioking
  • 19
Message 7 of 17
02/01/2020 21:02:29 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=CMTS-MAC=CM-QOS=1.1;CM-VER=3.0;
02/01/2020 21:02:31 Warning! RCS Partial Service;CM-MAC=CMTS-MAC=CM-QOS=1.1;CM-VER=3.0;
02/01/2020 21:02:33 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
02/01/2020 21:02:33 Warning! RCS Partial Service;CM-;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
03/01/2020 01:11:52 critical No Ranging Response received - T3 time-out;CM-MAC=CMTS-MAC=CM-QOS=1.1;CM-VER=3.0;
03/01/2020 12:05:15 Warning! Lost MDD Timeout;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
  • 22.41K
  • 2.4K
  • 3.99K
Message 8 of 17
Offshore are mostly untrained droids who read from scripts. You wont get any call back so dont wait in.
A VM forum staff member should pick this up on here in a day or two and arrange a visit with you.
Or a VIP might ping them from here to speed things up a little.
David_Bn
  • 4.91K
  • 226
  • 402
Message 9 of 17
Thanks for your post canioking
Sorry to see you've been having issues with your broadband services.
I'd be happy to take a closer look into this for you, please check out the purple envelope in the top right hand corner for a PM from me
Kindest regards,
David_Bn
canioking
  • 19
Message 10 of 17
2 weeks gone by and back to square one . Speeds dropped to 20mbps should be getting 100mbps . Waste of time ringing up for help so hopefully will gets answers on here . Waiting a response?
