tico1874
  • 12
Message 1 of 14
Internet Speed is so inconsistent
My internet speed is all over the place. I have a Super Hub 3.
I've never had any issues before, but we've just moved house and now the speed ranges from 200mbps to 1mbps.
This happens from minute to minute, making connection to the remote desktop my wife uses for work impossible. She basically can't do her job. Zoom calls are also impossible.
I've reset the router via the pinhole, and still the problem persists. The status page is saying there are no issues locally. It must either be the router or the broadband coming into the house.
Please can someone help!
  • 23.79K
  • 2.52K
  • 4.31K
Message 2 of 14
Re: Internet Speed is so inconsistent
It "could" be a poor connection somewhere, so firstly, can you check that all of your coax cable connections are in nice and "finger" tight - at the Hub and wall box and also at any connectors etc. Ensure there are no “unterminated cable loose ends ore loose connectors. Disconnect all the connections and reconnect to be sure. Also check that the internal wiring is ok with no kinking or chaffing to the insulation, check that all looks good with the outside cabling and wall box too.
Can you then post up the data from the Hub settings as per many posts on this forum.
tico1874
  • 12
Message 3 of 14
Thanks John.
The wiring inside and out all looks fine. There hasn't been anything which would have changed things, at least not inside the house.
This is the BMQ data from the last four hours or so. I'm sure it will mean more to you than it does to me! It feels like there is an especially high level of packet loss, averaging at least 10% over that time.
  • 23.79K
  • 2.52K
  • 4.31K
Message 4 of 14
I can see it now and it looks absolutely dreadful ! We need to see those Hub stats - do it as per this procedure.
____________________________________
In your browser’s URL box type in http://192.168.0.1  (or http://192.168.100.1 - if in modem mode) and hit return. On the first page up [there should be no need to login if you have done so before unless you have the New Hub4 when you do] click on the “router status” icon/text at bottom-middle of first page up and then copy/paste as “Formatted Text” (not images) 3 FULL sets of data onto here – 2 pages from the Downstream, 2 from the Upstream, & the Network Logs page. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again. Or split into 2 posts if characters get exceeded.
tico1874
  • 12
Message 5 of 14
Sorry John, I think I'm being dense - I can't see any button which says 'router status'...
MckeithyB
  • 23
Message 6 of 14
Its the link below the login box, before you login.
  • 23.79K
  • 2.52K
  • 4.31K
Message 7 of 14
As said... but you have logged in at least once before and altered the password from the default on its sticker - havent you ?
If not do so and then log out and disconnect - reconnect and it will appear at the bottom of the page
tico1874
  • 12
Message 8 of 14
Hello,
Sorry, I've figured it out. Here is the data.
133075000014.540256 qam25
220275000013.640256 qam9
321075000013.640256 qam10
421875000013.540256 qam11
52267500001338256 qam12
623475000012.838256 qam13
724275000012.538256 qam14
825075000012.340256 qam15
925875000012.938256 qam16
1026675000014.338256 qam17
1127475000014.640256 qam18
1228275000014.640256 qam19
1329075000014.940256 qam20
1429875000015.140256 qam21
153067500001540256 qam22
163147500001540256 qam23
173227500001540256 qam24
1833875000013.938256 qam26
1934675000013.840256 qam27
2035475000013.640256 qam28
2136275000013.440256 qam29
2237075000013.640256 qam30
233787500001440256 qam31
2438675000013.940256 qam32
1Locked40.3156434335753
2Locked40.3146805495411
3Locked40.3144508471383
4Locked40.3135779463016
5Locked38.9133752501250
6Locked38.9135540479885
7Locked38.9132526466731
8Locked40.3131701418143
9Locked38.9127650394375
10Locked38.9128626386414
11Locked40.3134316404386
12Locked40.3137451391567
13Locked40.9144569383610
14Locked40.3149374403836
15Locked40.9157840392722
16Locked40.3159134384969
17Locked40.9161401368040
18Locked38.9157631380701
19Locked40.3151060408473
20Locked40.3154507364707
21Locked40.3153038318976
22Locked40.9160458299428
23Locked40.3166997306905
24Locked40.3168289295801
15370000039.8512064 qam8
24620000039.3512064 qam9
33940000039.5512064 qam10
46030000040512064 qam7
1ATDMA00220
3ATDMA0010
4ATDMA0000
Network log wouldn't fit in this message - in the next message.
Thank you in advance for your help on this!
tico1874
  • 12
Message 9 of 14
26/06/2021 09:07:20Warning!RCS Partial Service;
26/06/2021 09:07:20criticalSYNC Timing Synchronization failure - Loss of Sync;
26/06/2021 09:05:4Warning!RCS Partial Service;
26/06/2021 09:05:4criticalSYNC Timing Synchronization failure - Loss of Sync;
26/06/2021 09:04:37Warning!RCS Partial Service;
26/06/2021 09:04:37criticalSYNC Timing Synchronization failure - Loss of Sync;
26/06/2021 09:01:20Warning!RCS Partial Service;
26/06/2021 09:01:20criticalSYNC Timing Synchronization failure - Loss of Sync;
26/06/2021 09:01:17Warning!RCS Partial Service;
26/06/2021 09:01:17criticalSYNC Timing Synchronization failure - Loss of Sync;
26/06/2021 09:00:8Warning!RCS Partial Service;CM-
26/06/2021 09:00:8criticalSYNC Timing Synchronization failure - Loss of Sync;
26/06/2021 08:55:32Warning!RCS Partial Service;
26/06/2021 08:55:32criticalSYNC Timing Synchronization failure - Loss of Sync;
26/06/2021 08:55:32Warning!RCS Partial Service;CM-
26/06/2021 08:55:13Warning!RCS Partial Service;CM-
26/06/2021 08:55:13criticalSYNC Timing Synchronization failure - Loss of Sync;
26/06/2021 08:52:16Warning!RCS Partial Service;CM-
26/06/2021 08:52:15criticalSYNC Timing Synchronization failure - Loss of Sync;CM-
Latest BQM data:
tico1874
  • 12
Message 10 of 14
Final thing to say is that our Virgin Media TV is being effected too. We are having lots of pixellation and the picture cutting out.
