nikosdim1987
  • 6
Internet Connection slow and flaky
Hi All
I am having a virgin media connection of 100mbps but the whole day today the connection was slow and flaky. I wasn't using any VPN. Just Virgin Media using Hub 3.
When I was doing speed test in the morning ~8:30-9am I was getting a speed of 20-30 mbps with loads of disconnections and wifi breaks. And throughout the day speed tests don't give more than 50mbps.
I have restarted the router 2-3 times but still.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Internet Connection slow and flaky
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
