hicky
  • 18
Intermittent speed/quality
Hi,  I'm getting intermittent issue with internet connectivity throughout the day.  Is there anything below which indicates my levels might be the cause...?
13230000001037256 qam24
218700000010.838256 qam7
319500000010.638256 qam8
420300000010.438256 qam9
521100000010.438256 qam10
621900000010.638256 qam11
722700000010.438256 qam12
823500000010.138256 qam13
92430000001038256 qam14
102510000001038256 qam15
112590000001038256 qam16
122670000001038256 qam17
132750000001038256 qam18
1428300000010.338256 qam19
152910000001038256 qam20
1629900000010.338256 qam21
1730700000010.338256 qam22
183150000009.538256 qam23
19443000000937256 qam25
204510000009.137256 qam26
214590000009.137256 qam27
224670000008.937256 qam28
234750000008.937256 qam29
244830000008.837256 qam30
1Locked37.68210
2Locked38.94890
3Locked38.94830
4Locked38.610870
5Locked38.63660
6Locked38.93950
7Locked38.63810
8Locked38.65820
9Locked38.67160
10Locked38.65180
11Locked38.64060
12Locked38.67380
13Locked38.64680
14Locked38.94160
15Locked38.97930
16Locked38.68190
17Locked38.66600
18Locked38.622200
19Locked37.628530
20Locked37.329300
21Locked37.326430
22Locked37.340380
23Locked37.642160
24Locked37.351220
5/07/2020 20:43:16criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/07/2020 01:26:40ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/07/2020 00:33:21ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/07/2020 01:46:2criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/07/2020 05:18:9ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 03:44:39ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/07/2020 12:58:31criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 06:02:6ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/07/2020 23:50:10ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/07/2020 22:16:15criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/07/2020 05:14:33ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/07/2020 04:13:26noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/06/2020 10:20:25ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/06/2020 07:07:52ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/06/2020 05:47:3criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/06/2020 03:55:22ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/06/2020 01:04:7criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2020 08:40:22ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
gary_dexter
  • 30.28K
  • 1.88K
  • 4.03K
Re: Intermittent speed/quality
Your downstream levels are too high.
Post the upstream levels too
hicky
  • 18
Hi Gary,
Thanks for replying.
I suspected they might be but wasn't sure if high enough to cause a problem.
Upstream are as follows :
1394000003.825512064 qam2
2258001333.725512064 qam4
3462000003.8512064 qam1
4326000003.825512064 qam3
3ATDMA0000
4ATDMA0000
Do I need to report fault or will someone from Virgin Media pick it up on here?
Thanks for your help with this.
Gareth_L
  • 6.1K
  • 373
  • 657
Hello hicky
Thanks for your post, sorry though to see you are having issues with the internet
I am more than happy to take a look at this for you
I will need to send you a private message to pass security
If you can check the purple envelope top right of your screen that would be great
Gareth_L
