Hello,
Since about three weeks ago my broadband started to disconnect and slow down very frequently. I have tried all the troubleshooting I could find here, but no luck. I get slow connections via ethernet. I have restarted the router which has made no difference for me too. it comes back and goes away randomly.
I'm on m200 and only getting 14.5 download and 0.8 Mbps upload speeds.
Please see below for logs from my Hub (Super Hub 2) which may hopefuly help to identify a problem:
First Time | Last Time | Priority | Error Number | Description |
17/05/2021 17:44:26 GMT | 17/05/2021 17:44:26 GMT | Critical (3) | 82000200 | No Ranging Response received - T3 time-out |
17/05/2021 17:40:04 GMT | 17/05/2021 17:40:04 GMT | Critical (3) | 82000200 | No Ranging Response received - T3 time-out |
17/05/2021 17:39:13 GMT | 17/05/2021 17:39:13 GMT | Critical (3) | 82000200 | No Ranging Response received - T3 time-out |
17/05/2021 17:38:10 GMT | 17/05/2021 17:38:10 GMT | Critical (3) | 82000200 | No Ranging Response received - T3 time-out |
17/05/2021 17:36:18 GMT | 17/05/2021 17:36:18 GMT | Critical (3) | 82000200 | No Ranging Response received - T3 time-out |
17/05/2021 17:34:54 GMT | 17/05/2021 17:34:54 GMT | Critical (3) | 82000200 | No Ranging Response received - T3 time-out |
17/05/2021 17:34:53 GMT | 17/05/2021 17:34:53 GMT | Critical (3) | 82000200 | No Ranging Response received - T3 time-out |
17/05/2021 17:15:20 GMT | 17/05/2021 17:15:20 GMT | Critical (3) | 82000200 | No Ranging Response received - T3 time-out |
17/05/2021 17:13:29 GMT | 17/05/2021 17:13:29 GMT | Critical (3) | 82000200 | No Ranging Response received - T3 time-out |
17/05/2021 17:13:25 GMT | 17/05/2021 17:13:25 GMT | Critical (3) | 82000200 | No Ranging Response received - T3 time-out |
17/05/2021 17:07:42 GMT | 17/05/2021 17:07:42 GMT | Critical (3) | 82000200 | No Ranging Response received - T3 time-out |
17/05/2021 17:06:54 GMT | 17/05/2021 17:06:54 GMT | Critical (3) | 82000200 | No Ranging Response received - T3 time-out |
17/05/2021 17:03:06 GMT | 17/05/2021 17:03:06 GMT | Critical (3) | 82000200 | No Ranging Response received - T3 time-out |
17/05/2021 17:02:03 GMT | 17/05/2021 17:02:03 GMT | Critical (3) | 82000200 | No Ranging Response received - T3 time-out |
17/05/2021 16:58:45 GMT | 17/05/2021 16:58:45 GMT | Critical (3) | 82000200 | No Ranging Response received - T3 time-out |
17/05/2021 16:58:15 GMT | 17/05/2021 16:58:15 GMT | Critical (3) | 82000200 | No Ranging Response received - T3 time-out |
17/05/2021 16:52:28 GMT | 17/05/2021 16:52:28 GMT | Critical (3) | 82000200 | No Ranging Response received - T3 time-out |
17/05/2021 16:50:38 GMT | 17/05/2021 16:50:38 GMT | Critical (3) | 82000200 | No Ranging Response received - T3 time-out |
17/05/2021 16:49:47 GMT | 17/05/2021 16:49:47 GMT | Critical (3) | 82000200 | No Ranging Response received - T3 time-out |
17/05/2021 16:48:40 GMT | 17/05/2021 16:48:40 GMT | Critical (3) | 82000200 | No Ranging Response received - T3 time-out |
Downstream DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz) | 138750000 | 146750000 | 154750000 | 162750000 | 170750000 | 178750000 | 186750000 | 194750000 |
Lock Status(QAM Lock/FEC Sync/MPEG Lock) | Locked | Locked | Locked | Locked | Locked | Locked | Locked | Locked |
Channel ID | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 |
Modulation | 256QAM | 256QAM | 256QAM | 256QAM | 256QAM | 256QAM | 256QAM | 256QAM |
Symbol Rate (Msym/sec) | 6.952000 | 6.952000 | 6.952000 | 6.952000 | 6.952000 | 6.952000 | 6.952000 | 6.952000 |
Interleave Depth | I=12 J=17 | I=12 J=17 | I=12 J=17 | I=12 J=17 | I=12 J=17 | I=12 J=17 | I=12 J=17 | I=12 J=17 |
Power Level (dBmV) | 6.81 | 6.68 | 6.69 | 6.01 | 6.18 | 6.43 | 6.20 | 5.76 |
RxMER (dB) | 35.42 | 35.42 | 35.97 | 35.78 | 36.17 | 36.39 | 36.61 | 35.97 |
Pre RS Errors |
61138762 | 32608842 | 4929060 | 4347108 | 3873078 | 3786603 | 4000378 | 4478679 |
Post RS Errors |
44232020 | 3159603 | 1979872 | 779682 | 150565 | 107976 | 229547 |
Upstream US-1 US-2 US-3 US-4
Channel Type | 2.0 | 2.0 | 2.0 | 2.0 |
Channel ID | 8 | 6 | 5 | 7 |
Frequency (Hz) | 25800000 | 39400000 | 46200000 | 32600000 |
Ranging Status | Success | Success | Success | Success |
Modulation | 32QAM | 16QAM | 16QAM | 64QAM |
Symbol Rate (Sym/sec) | 5120000 | 5120000 | 5120000 | 5120000 |
Mini-Slot Size | 2 | 2 | 2 | 2 |
Power Level (dBmV) | 45.54 | 46.96 | 47.46 | 46.50 |
T1 Timeouts | 0 | 0 | 0 | 0 |
T2 Timeouts | 0 | 0 | 0 | 0 |
T3 Timeouts | 36 | 35 | 32 | 38 |
T4 Timeouts | 0 | 0 | 0 | 0 |
Upstream Burst Req(1) Init Maint(3) Per Maint(4) Adv Short(9) Adv Long(10) Adv UGS(11)
Modulation Type | 16QAM | QPSK | 16QAM | 32QAM | 32QAM | 16QAM |
Differential Encoding | OFF | OFF | OFF | OFF | OFF | OFF |
Preamble Length | 56 | 640 | 384 | 104 | 104 | 104 |
Preamble Value Offset | 652 | 0 | 0 | 716 | 716 | 716 |
FEC Error Correction (T) | 0 | 5 | 5 | 8 | 13 | 5 |
FEC Codeword Information Bytes (K) | 16 | 34 | 34 | 114 | 220 | 86 |
Maximum Burst Size | 0 | 0 | 0 | 4 | 255 | 255 |
Guard Time Size | 8 | 48 | 48 | 8 | 8 | 8 |
Last Codeword Length | Fixed | Fixed | Fixed | Shortened | Shortened | Shortened |
Scrambler On/Off | ON | ON | ON | ON | ON | ON |
Please could somebody take a look and advise? Thank you.
