ZMacKay
Intermittent speed on m350 sometimes less than 1mbps
The download speeds range from above 300mbps to sometimes as low as less than one. I’ve tried every troubleshooting tip I can think of, have tried calling virgin and even had responses on Twitter with no help so far.
I've used the app to try improve connection across the house but I even have issues at my desk which is about 4 meters away from the hub with no obstructions.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Intermittent speed on m350 sometimes less than 1mbps
Which Hub do you have ?
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
ZMacKay
Hi Mike,
I think it's the hub 3 router?
Over ethernet, we get 16ms ping, 388mbps down, and 36mbps up. Wi-Fi isn't that different in terms of speed it's just the issue of it often dropping to almost nothing on a range of devices in the house.
