UhtredtheBold
Intermittent packet loss to some sites
Hi I'm in area 24 and i've been experiencing intermittent packet loss to some sites.
This started on 31/10/20 with the past 3 days being particularly bad.
I've been running continuous ping tests to various IPs out on the internet today and while some are experiencing ~60% packet loss, others haven't dropped a single ping.
Youtube is buffering often, my wife's work vpn is frequently disconnecting but my work vpn is absolutely fine...
I was going to post some pathping data but the packet loss has suddenly stopped for now. I will update the post when I manage to capture this.
Here are some live graphs where you can see the packet loss for the past 24 hours.
http://f8luresig.mouselike.org/sig.png?/54481.png
https://f8lure.mouselike.org/proxyfirebrick.asp?ID=54481
https://www.thinkbroadband.com/broadband/monitoring/quality/share/90c3de53d17335a0e253982a5662e41d39...
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Intermittent packet loss to some sites
Can you please
UhtredtheBold
1403000000038256 qam30
2203000000238256 qam9
32110000001.938256 qam10
42190000001.938256 qam11
52270000001.538256 qam12
62350000001.238256 qam13
72430000000.738256 qam14
82510000000.738256 qam15
9259000000138256 qam16
102670000001.538256 qam17
112750000001.538256 qam18
122830000001.538256 qam19
132910000001.238256 qam20
142990000001.238256 qam21
153070000001.438256 qam22
163150000001.238256 qam23
173230000001.238256 qam24
183310000001.238256 qam25
193710000000.238256 qam26
203790000000.238256 qam27
213870000000.238256 qam28
223950000000.238256 qam29
23411000000038256 qam31
24419000000038256 qam32
1Locked38.610448
2Locked38.97289
3Locked38.670100
4Locked38.961187
5Locked38.654165
6Locked38.67695
7Locked38.655121
8Locked38.967134
9Locked38.652134
10Locked38.649135
11Locked38.953174
12Locked38.940130
13Locked38.951111
14Locked38.661103
15Locked38.957121
16Locked38.96291
17Locked38.68689
18Locked38.986109
19Locked38.97835
20Locked38.910934
21Locked38.610255
22Locked38.98153
23Locked38.613184
24Locked38.915464
16030000043.8512064 qam1
23940000041.3512064 qam4
34620000042.8512064 qam3
45370000043.8512064 qam2
2ATDMA0020
3ATDMA0020
4ATDMA0010
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
g87dsfd;kfoA,.iyewrkldJKDHSUBsgvca
SFID18859
10/11/2020 03:44:5criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 08:22:5noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxl20016u+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 08:22:5ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/11/2020 19:31:25ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/11/2020 12:19:48Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/11/2020 06:40:49ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/11/2020 01:27:25criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/11/2020 23:38:31Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/11/2020 22:42:2criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/11/2020 20:10:50Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/10/2020 17:53:2criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/10/2020 12:39:2Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/10/2020 10:28:4criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/10/2020 09:32:45Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/10/2020 05:35:32criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 13:29:35noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxl20016u+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 13:29:35ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 09:24:43ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 07:05:41criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 05:19:54ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Natalie_L
  • 2.65K
  • 120
  • 231
Hi UhtredtheBold
Thank you for posting to the Community.
My apologies for the delay, we have been a little busier than usual at the moment.
I have taken a look from our side and everything appears to be running in within spec.
How has the service been since you last posted please? Have you noticed any improvements?
If not, please let me know and I will be happy to assist.
Nat
