fenixriot
  • 84
Message 1 of 19
Intermittent issues
For over 12 months now my 350mb internet has been great, however over the last couple of weeks I have noticed latency is all over the place and the speed drops to below 100mb at times, also the upload can go from the usual 30mb to under 10mb.
I am currently using thinkbroadband to monitor the connection and will post the graph after leaving over night.
AngryJackedJoe
  • 52
  • 42
Dialled in
Message 2 of 19
Re: Intermittent issues
Your going to be joining the rest of us come tomorrow, looking at the graph going what on earth is going on at Virgin.
Look at almost all the recent posts, everyone is complaining about issues like:
There seems to be a trend, at peak times everyones packets latency goes through the roof and there is packetloss.
Alot of speculation, but no virgin dont seem to be fixing as its been happening since early in March.
Welcome to the pain!
fenixriot
  • 84
Message 3 of 19
Yeah, looks like there is a much wider issue then if it’s affecting loads of people. So thinking of switching back to BT now they have their 900mb broadband in my area. Cheers.
Steven_L
  • 11.34K
  • 689
  • 1.15K
Message 4 of 19
Hey @fenixriot,
Welcome back to the community and thanks for taking the time to post.
I'm sorry to hear of the issues that you're having with your connection, I have into this and cannot see anything with your connection or in the local area that would be causing these issues. How has your connection been running since you last posted?
Regards,
Steven_L
minichris
  • 75
  • 8
Dialled in
Message 5 of 19
Someone will have to take ownership of this issue soon.....
fenixriot
  • 84
Message 6 of 19
Still terrible lag and download  speeds have dropped from over 360mb to 170mb, this kind of stability is terrible for online gaming!!! I am seriously considering going back to BT!!!
Nathan_B
  • 5.04K
  • 170
  • 335
Message 7 of 19
Hi there @fenixriot, thanks for letting us know you are still having this issue. Apologies for any inconvenience caused.
I can see that you have spoken with the team since your last reply. Were they able to help have this resolved?
Nathan
fenixriot
  • 84
Message 8 of 19
They said they have reset the connection their end??! And that an engineer is working on the issue??! I don’t think they understand that it is the latency I’m having issues with and not download speeds, however they kept talking about that. As stated earlier in this thread it probably is due to over utilisation as the lag spikes seem to occur at peak times.
Tom_W1
  • 3.66K
  • 198
  • 342
Message 9 of 19
Hi @fenixriot thanks for your reply to us.
I'm sorry but we cannot identify any issues on the line as previously explained - we've re-ran the tests and all power levels, and upstream/downstream levels are within specifications, demonstrating there's no signs of any congestion on the line either.
Can you please try to have your Hub in Router Mode and let us know how you get on via this method, when connected via ethernet directly into your Hub please?
Many thanks
Tom_W
fenixriot
  • 84
Message 10 of 19
I have already tried this and it makes no difference, clearly if there is no issue to the line it is clearly a problem with over utilisation. Same issue I had 3 years ago and I switched to BT then.
