  • 34
Intermittent dropouts
I stream and have had to stop due to the upload taking a nosedive these last few days.
I have the superhub 3 in modem mode and use a powerline mesh system. Zero problems up until the last few days.
I've set up a BQM. In the meantime here are my router stats for upload and download.
Hope I'm doping this right...
1483000000040256 qam30
21870000004.540256 qam7
31950000004.340256 qam8
4203000000440256 qam9
52110000003.740256 qam10
62190000003.440256 qam11
72270000003.440256 qam12
8235000000340256 qam13
92430000002.740256 qam14
102510000002.740256 qam15
112590000002.740256 qam16
12267000000340256 qam17
132750000002.940256 qam18
142830000002.940256 qam19
152910000002.740256 qam20
162990000002.740256 qam21
173070000002.740256 qam22
183150000002.540256 qam23
193230000002.440256 qam24
204430000000.540256 qam25
214510000000.240256 qam26
22459000000040256 qam27
23467000000040256 qam28
24475000000-0.240256 qam29
1Locked40.3190
2Locked40.950
3Locked40.350
4Locked40.350
5Locked40.340
6Locked40.350
7Locked40.370
8Locked40.370
9Locked40.350
10Locked40.350
11Locked40.310
12Locked40.360
13Locked40.960
14Locked40.350
15Locked40.350
16Locked40.360
17Locked40.960
18Locked40.360
19Locked40.390
20Locked40.320
21Locked40.350
22Locked40.360
23Locked40.390
24Locked40.3200
  • 34
Re: Intermittent dropouts
1 53700000 4.45 5120 64 qam 7
2 39400000 4.4 5120 64 qam 9
3 46200000 4.4 5120 64 qam 8
4 32600000 4.375 5120 64 qam 10
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
30/01/2020 16:33:58 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/01/2020 16:30:41 Warning! LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/01/2020 02:15:9 Error DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/01/2020 04:03:13 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/01/2020 20:30:48 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/01/2020 18:39:44 Error DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/01/2020 14:01:48 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/01/2020 08:35:25 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/01/2020 05:00:53 notice SW download Successful - Via NMS
20/01/2020 05:00:32 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/01/2020 04:59:29 notice SW Download INIT - Via NMS
19/01/2020 07:45:17 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/01/2020 01:44:57 Error DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/01/2020 20:03:43 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2020 07:12:44 Error DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/01/2020 11:08:19 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/01/2020 12:39:20 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/01/2020 09:32:23 Error DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/01/2020 02:28:45 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/2020 13:57:20 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 3.57K
  • 196
  • 546
Community elder
What speeds do you get with a device connected directly to the Hub?
  • 34
I'm on the 500mb package.
Speed isn't the issue, I get around 150mb down and the full 35 up wired directly to my powerline mesh hub. Happy with that.
Problem is that it drops off significantly, both up and down, to the point of being unusable. Then comes back.
Also having a problem with the TV box trying to connect to the second one upstairs, recorded programmes pausing, going out of sync.So I know it's not restricted to the one mesh node. I even prioritised the main PC in the mesh software. Made no difference.
Here's my BQM for the last 24hrs. No idea if I set it up correctly. Seems ok?
  • 34
Speeds aren't an issue.
I'm concerned with the sudden drops.
I tried to upload an image of my BQM but the forum won't accept any URL uploads, saying pls input a complete URL. I also tried uploading a saved image from my PC but the post was removed.
I'll just cancel Virgin.
  • 6.08K
  • 310
  • 539
Hi GuitarJoe,
Thanks for posting. I am sorry for the drop out issues you've had. I've ran a background check here and no issues are showing.
When the connection drops, do all devices lose connection at the same time?
Kind regards,
John_GS
