forumarchive,nothingtosee,
RichieDD
  • 12
Message 1 of 15
Intermittent download speed weeks after installation
We had M500 Fibre Broadband installed at the end of December 2020 (new customer) and after the engineer hooked everything up he showed us the down and up speeds which were approx 550mbps and 36mbps. The speeds seemed to remain consistent for a couple of weeks, but then started to vary by quite a bit; we can go from 550 down to 350 down, in around an hour. Done the normal checks, nothing else connected to the router, restarted, wired connection, but we still get this very large difference in speed. The time of the day doesn't seem to matter, sometimes we'll get 550 down in the evenings and only 400 down at 14:00 in the afternoon. One really strange thing is that the speed seems to dip every time it rains.
Would someone be able to check our line to make sure everything is still as it should be / was, when we first had the installation, please?
15310000004.438256 qam16
25230000004.438256 qam15
3539000000438256 qam17
4547000000438256 qam18
55550000003.438256 qam19
6563000000338256 qam20
7571000000338256 qam21
85790000002.538256 qam22
95870000002.438256 qam23
105950000001.738256 qam24
116030000002.238256 qam25
126110000001.738256 qam26
136190000001.738256 qam27
146270000001.538256 qam28
156350000001.438256 qam29
166430000001.238256 qam30
176510000001.538256 qam31
186590000001.538256 qam32
196670000001.738256 qam33
206750000001.738256 qam34
216830000001.538256 qam35
226910000001.738256 qam36
236990000001.538256 qam37
247070000001.538256 qam38
1Locked38.9210
2Locked38.9260
3Locked38.9120
4Locked38.9210
5Locked38.9280
6Locked38.6150
7Locked38.9250
8Locked38.6190
9Locked38.6240
10Locked38.6360
11Locked38.9200
12Locked38.9250
13Locked38.6160
14Locked38.9160
15Locked38.6170
16Locked38.9310
17Locked38.9460
18Locked38.6440
19Locked38.9200
20Locked38.9120
21Locked38.6150
22Locked38.9140
23Locked38.9190
24Locked38.9120
14620011643.8512064 qam3
25369999544.5512064 qam2
33940003443.8512064 qam4
43260045843.8512064 qam5
3ATDMA0000
4ATDMA0000
(Red line on the left side of the chart is due to a router reboot)
RichieDD
  • 12
Message 2 of 15
Re: Intermittent download speed weeks after installation
Just noticed this in the router network log,
08/02/2021 20:37:53criticalNo Ranging Response received - T3 time-out;CM-MAC=XXXXXXXXXX;CMTS-MAC=XXXXXXXXXX;CM-QOS=1.1;CM-VER=3.0;
RichieDD
  • 12
Message 3 of 15
Would appreciate some input here please, even if it's to confirm that this is expected behaviour.
Plus, just got the below
09/02/2021 03:19:20ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=XXXXXXXXXX;CMTS-MAC=XXXXXXXXXX;CM-QOS=1.1;CM-VER=3.0;
RichieDD
  • 12
Message 4 of 15
and again,
11/02/2021 14:39:51criticalNo Ranging Response received - T3 time-out;CM-MAC=XXXXXXXXXX;CMTS-MAC=XXXXXXXXXX;CM-QOS=1.1;CM-VER=3.0;
RichieDD
  • 12
Message 5 of 15
This today,
12/02/2021 08:46:51ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=XXXXXXXXXX;CMTS-MAC=XXXXXXXXXX;CM-QOS=1.1;CM-VER=3.0;
RichieDD
  • 12
Message 6 of 15
Download speed is still varying significantly with no obvious correlation to peak / offpeak times.
I'd really appreciate an opinion here; is this expected behaviour, or is there likely to be a problem somewhere along the line?
Thank you
RichieDD
  • 12
Message 7 of 15
Updating downstream channels,
15310000003.538256 qam16
25230000003.538256 qam15
3539000000338256 qam17
4547000000338256 qam18
55550000002.538256 qam19
65630000002.238256 qam20
7571000000238256 qam21
85790000001.538256 qam22
95870000001.438256 qam23
105950000000.538256 qam24
116030000001.238256 qam25
126110000000.738256 qam26
136190000000.738256 qam27
146270000000.538256 qam28
156350000000.238256 qam29
166430000000.238256 qam30
176510000000.438256 qam31
186590000000.438256 qam32
196670000000.738256 qam33
206750000000.538256 qam34
216830000000.438256 qam35
226910000000.538256 qam36
236990000000.238256 qam37
247070000000.438256 qam38
1Locked38.6970
2Locked38.91820
3Locked38.9720
4Locked38.91020
5Locked38.91270
6Locked38.6890
7Locked38.91740
8Locked38.61650
9Locked38.91830
10Locked38.92400
11Locked38.61140
12Locked38.91570
13Locked38.9990
14Locked38.91390
15Locked38.61420
16Locked38.61860
17Locked38.92530
18Locked38.62010
19Locked38.6970
20Locked38.6770
21Locked38.6950
22Locked38.9570
23Locked38.9420
24Locked38.9740
  • 20.62K
  • 2.19K
  • 3.64K
Message 8 of 15
Nothing you have posted in the last two weeks is giving any clues as to what is causing your issues. Indeed can you say again what they actually are on ethernet connected devices and on wifi ones
RichieDD
  • 12
Message 9 of 15
Appreciate the reply. The speed drops are experienced across all devices, both wired and wifi, although the speed tests I've done to verify have been on wired devices only, as to not include wifi in the equation as well. Devices include iPhones, iPads and Xbox for wifi and Macbook Pros, Mac minis, Windows 10 machines for wired.
As mentioned above, I have confirmed the speed drops via speed tests with only one wired device connected to the network.
  • 20.62K
  • 2.19K
  • 3.64K
Message 10 of 15
Can you post up the link to the "share live graph" BQM so we can see how it is looking at the moment.
Speed fluctuations on the scale you originally cited in message 1 dont seem to be out of the ordinary to me - they are within the VM "guaranteed range" - are they not ?
Can you test this way when you are within a period of low speeds.
Put the Hub into “modem mode” (see VM website for “How To”) and connect your W10 laptop to it. Test at speedtest.net (not using their App!) to your nearest VM server - try on 2 different browsers.
If they are still low – boot the W10 device into windows safe+networking mode and try again.
Report back what that gets - should be at the Max.
