fcsics
  • 7
Message 1 of 13
Intermittent connection
I'm a new VM customer on the M350 fibre broadband and we had quite a few issues to get any connection at all. After two weeks and installing a new drop from the flat to the ground level, a VM engineer used a splitter to use the neighbour's cable and connect our new drop to the input cable from the ground (as the engineer said, a new cable has to be done between our house and cable cabinet a few hundred meters further down the road- in theory this was requested but I cannot get any information). While we finally got a connection, it is cutting out every few minutes as if due to the splitter and sharing the cable with another customer. I'm curious to hear from experienced commenters /moderators about where could I check to see the date of the cable is going to be done and/or any tips that would help resolve the issue.
ps.: my problem is similar to mannz's latency issue - here's the link to that:
https://community.virginmedia.com/t5/Speed/High-Latency-Issues/m-p/4410794#M242350
Anonymous
Not applicable
Message 2 of 13
Re: Intermittent connection
Paste the HUB data and we can have a look?
Could you access your router using http://192.168.0.1/ or http://192.168.100.1 for modem mode . You shouldn't need log in, select the 'Check Router Status' option and paste your 'Downstream', 'Upstream', and 'Network Log' tabs? Please copy/paste this data as text, split between multiple posts (Sometimes you have to click 'Post' twice due to an error message).
Could you please create a BQM (Broadband Quality Monitor) here, and post the live link?
fcsics
  • 7
Message 3 of 13
Downstream:
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
1203000000-3.733256 qam9
2139000000-0.937256 qam1
3147000000038256 qam2
41550000000.538256 qam3
51630000000.738256 qam4
61710000000.538256 qam5
7179000000-0.538256 qam6
8187000000-1.538256 qam7
9195000000-2.938256 qam8
10211000000-3.537256 qam10
11235000000-1.738256 qam13
12243000000-2.538256 qam14
13251000000-3.238256 qam15
14259000000-4.238256 qam16
15267000000-4.938256 qam17
16275000000-538256 qam18
17283000000-4.738256 qam19
18291000000-4.738256 qam20
19299000000-438256 qam21
20307000000-4.238256 qam22
21315000000-4.937256 qam23
22323000000-5.737256 qam24
1Locked33.9172554157829236
2Locked37.3137374485
3Locked38.6128736703
4Locked38.910888278
5Locked38.99264282
6Locked38.910169368
7Locked38.615480724
8Locked38.62186815493
9Locked38.6249642402
10Locked37.6166511609
11Locked38.96427381
12Locked38.65826731
13Locked38.67695955
14Locked38.6131361071
15Locked38.6163941292
16Locked38.615429992
17Locked38.68782779
18Locked38.67291382
19Locked38.64716150
20Locked38.6461498
21Locked37.69029643
22Locked37.611484419
fcsics
  • 7
Message 4 of 13
Upstream
1326001755.1512064 qam5
2393998475.1512064 qam4
3461999515.1512064 qam3
4258000875.1512064 qam6
3ATDMA0000
4ATDMA0000
fcsics
  • 7
Message 5 of 13
Network log:
24/09/2020 17:45:8Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2020 17:45:8Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2020 17:45:5Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2020 17:45:5criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2020 17:45:4Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2020 17:45:4criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2020 17:45:3criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2020 17:45:0Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2020 17:45:0Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2020 17:44:56Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2020 17:44:56criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2020 17:44:55Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2020 17:44:55criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2020 17:44:52Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2020 17:44:51criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2020 17:44:50Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2020 17:44:50criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2020 17:44:47Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2020 17:44:45criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0
Anonymous
Not applicable
Message 6 of 13
@fcsics wrote:
Upstream
13260017551512064 qam5
23939984751512064 qam4
34619995151512064 qam3
42580008751512064 qam6
3ATDMA0000
4ATDMA0000
Upstream power levels are too high and you have a SNR issue on one of your downstream channels (Probably causing the high Pre and Post RS Errors):
Lots of errors in your network stats.
fcsics
  • 7
Message 7 of 13
fcsics
  • 7
Message 8 of 13
Yes, I saw these (both network log problems and suspected the high errors as part of this problem. The only part I'm lost is solutions. 🙂
Anonymous
Not applicable
Message 9 of 13
Your link doesn't work (Partially cut off).
Anonymous
Not applicable
Message 10 of 13
An engineer visit is required to correct the issues on your line.
