DurSth
Intermittent connection issues
For the last week I’ve had intermittent connectivity issues on a daily basis. It lasts for 1.5-2 hours each time it happens, and during this period my upload speed will be close to 0mbps. My download speed is still 250+mbps, but due to the upload issue this means everything from Remote Desktop to internet browsing grinds to a halt.
My devices are wired so it’s not Wi-Fi related, and I’ve rebooted and reset the Hub3. The issue can also be seen in my BQM, where each time it happens the lost packages light up.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/9be2315163d10944057eb22fc590a56364084863
I have called VM customer service multiple times, and the only thing they say is that I can reboot the router, and that they have created a speed complaint which will take 30 days to receive feedback on. I need the internet for work, so waiting 30 days for an initial reply is completely unacceptable.
The phone and website Services check also say my area does not have any issues, however when I try to check my service during an issue the website says it can’t connect to my device.
Anyone know anything I can do to get the internet fixed please?
Thank you!
13307500001.740256 qam25
22027500001.238256 qam9
3210750000138256 qam10
4218750000138256 qam11
52267500000.738256 qam12
62347500000.538256 qam13
72427500000.740256 qam14
82507500000.740256 qam15
92587500000.740256 qam16
102667500000.740256 qam17
112747500000.740256 qam18
122827500000.240256 qam19
132907500000.238256 qam20
142987500001.538256 qam21
15306750000240256 qam22
16314750000240256 qam23
173227500001.940256 qam24
183387500001.240256 qam26
193467500001.240256 qam27
20354750000140256 qam28
213627500000.538256 qam29
223707500000.540256 qam30
233787500000.538256 qam31
243867500000.240256 qam32
1Locked40.31210
2Locked38.941520
3Locked38.936380
4Locked38.94140
5Locked38.69200
6Locked38.91820
7Locked40.32850
8Locked40.31290
9Locked40.93810
10Locked40.32050
11Locked40.91730
12Locked40.3790
13Locked38.9960
14Locked38.65300
15Locked40.37080
16Locked40.31000
17Locked40.3930
18Locked40.31380
19Locked40.31380
20Locked40.3780
21Locked38.91130
22Locked40.91160
23Locked38.948119309
24Locked40.31390
14620000042.2512064 qam2
22580000039.3512064 qam5
33260000039.8512064 qam4
43940000040.8512064 qam3
1ATDMA0020
2ATDMA0020
3ATDMA0020
4ATDMA0000
Anonymous
Not applicable
Re: Intermittent connection issues
Channel 23 downstream has loads of post RS errors which need addressing.
There are some T3 timeouts across three upstream channels.
Also the BQM shows curiously rigid two hour blocks of heavy packet loss.
Check for local faults on 0800 561 0061 again otherwise call it in as a fault with a view to an engineer.
David_Bn
  • 9.36K
  • 387
  • 712
Good Evening @DurSth, thanks for your post on our Community Forums, and a very warm welcome to you!
Sorry to hear of the recent broadband issues you've been experiencing.
Can you please advise us how the services are currently performing?
I've been able to look into the local area, and your hub statistics and no outages are currently present, with the hub looking in perfect health.
Kindest regards,
David_Bn
DurSth
Thanks for the tips @Cardiffman281!
@David_Bn the network has performed well for the last two days, so I’m crossing my fingers it won’t reoccur. I’ll message back here if it does within the next couple of days.
Thanks!
