OviDragan
Intermittent connection / download or upload speeds drops
Hello,
I have been having an issue with the connection over the past couple of days, it just comes and goes.
Restarted and rebooted my router to no effect.
Any help?
14027500000.438256 qam29
2250750000-0.238256 qam15
3258750000038256 qam16
42667500000.738256 qam17
52747500001.438256 qam18
62827500001.538256 qam19
72907500001.738256 qam20
82987500001.538256 qam21
93067500001.938256 qam22
103147500002.438256 qam23
113227500002.238256 qam24
123307500002.238256 qam25
133787500000.538256 qam26
143867500000.538256 qam27
153947500000.438256 qam28
164107500000.738256 qam30
174187500000.538256 qam31
184267500000.238256 qam32
19434750000038256 qam33
204427500000.238256 qam34
214507500000.538256 qam35
224587500000.438256 qam36
23466750000038256 qam37
244747500000.438256 qam38
15370000048512032 qam10
23940000048512032 qam12
34620000048512032 qam11
46030000048512032 qam9
1ATDMA0020
2ATDMA0040
3ATDMA0000
4ATDMA00120
18/06/2021 11:54:48criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/06/2021 11:54:48criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/06/2021 11:53:27criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/06/2021 11:53:27criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/06/2021 11:52:7criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/06/2021 11:52:7criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/06/2021 11:46:48criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/06/2021 11:46:47criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/06/2021 11:42:48criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/06/2021 11:42:48criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/06/2021 11:39:54noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/06/2021 11:34:49criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/06/2021 11:34:49criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/06/2021 11:33:58noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/06/2021 11:28:9criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/06/2021 11:28:9criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:03:7Warning!ToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/06/2021 11:18:30criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/06/2021 11:18:30criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/06/2021 11:04:48noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Andrew-G
  • 7K
  • 1.22K
  • 3.06K
Re: Intermittent connection / download or upload speeds drops
Based on the upstream channels only being 32 QAM accompanied by timeouts on three channels, I suspect it's an upstream noise issue.  I've marked for the forum staff, they'll take a look and advise appropriately.
Paulina_Z
  • 1.11K
  • 34
  • 69
Hi @OviDragan,
Welcome back to our Community Forums! Thank you for your post, and I'm sorry to hear that you have an ongoing issue with your connection.
Can you tell us if this issue is impacting you on your WiFi or Wired connections? Or both?
Have you taken a look at our WiFi Diagnostic page or even ran tests on your equipment via our Service Status page?
I was able to locate your account and as of this moment, I cannot see any issues with your upstream or downstream power levels.
How has your connection been since Friday? Please keep us updated if you can.
Thanks! 🙂
Paulina_Z
