Spitfire16
  • 161
  • 30
Up to speed
Message 1 of 5
Intermittent connection - Technician required?
Hi VM,
I'm having an intermittent connection where streams from twitch will pause for split seconds and my alexa's will pause while playing the radio,
Line stats are below for you to look , I'm posting from the virgin connection is question
330750000
Locked
Ranged Upstream Channel (Hz)
32600000
Locked
Provisioning State
Online
13307500004.340256 qam25
22587500001.738256 qam16
32667500002.238256 qam17
42747500002.538256 qam18
52827500002.940256 qam19
62907500003.240256 qam20
72987500003.938256 qam21
83067500003.940256 qam22
93147500004.440256 qam23
103227500004.140256 qam24
113707500004.540256 qam26
123787500004.440256 qam27
133867500004.440256 qam28
143947500004.540256 qam29
154027500004.140256 qam30
164107500004.540256 qam31
174187500004.440256 qam32
184267500004.540256 qam33
194347500004.639256 qam34
204427500004.540256 qam35
214507500004.940256 qam36
224587500004.338256 qam37
234667500004.640256 qam38
244747500004.338256 qam39
1Locked40.342081949699
2Locked38.92613225296
3Locked38.92545565366
4Locked38.92504694854
5Locked40.32491234848
6Locked40.32458664040
7Locked38.93199746276
8Locked40.32803857692
9Locked40.92672728548
10Locked40.333585120245
11Locked40.3444719107582
12Locked40.342406457609
13Locked40.337743535021
14Locked40.336169724606
15Locked40.338590021757
16Locked40.341521418290
17Locked40.335499516676
18Locked40.332952014106
19Locked39.335325311695
20Locked40.92907749856
21Locked40.32862516913
22Locked38.92614866114
23Locked40.32252925140
24Locked38.92558496068
13260000038512064 qam5
23940000038.5512064 qam4
34620000039.5512064 qam3
45370000039.5512064 qam2
1ATDMA0010
2ATDMA0030
3ATDMA0010
4ATDMA0000
Spitfire16
  • 161
  • 30
Up to speed
Message 2 of 5
Re: Intermittent connection - Technician required?
20/10/2020 14:57:32Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/10/2020 14:40:57criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/10/2020 14:31:42Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/10/2020 14:23:2criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/10/2020 03:54:29Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/10/2020 03:17:48criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/10/2020 02:31:21Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/10/2020 02:30:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/10/2020 01:31:37Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/10/2020 01:24:34criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/10/2020 19:56:0Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/10/2020 19:00:9criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/10/2020 16:45:29Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/10/2020 16:45:18noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/10/2020 16:45:18ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/10/2020 13:47:20Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/10/2020 12:12:21criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/10/2020 03:42:16Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/10/2020 03:32:14criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/10/2020 03:03:36Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 3 of 5
Spitfire16
  • 161
  • 30
Up to speed
Message 4 of 5
Katie_WT
  • 5.02K
  • 304
  • 569
Message 5 of 5
Hi there @Spitfire16
Thanks so much for popping along - sorry that you've had some intermittent connection; we do thank you for putting up your BQM; we can indeed see that you are seeing some dropout via that so we'll need to get a technician out.
I have located your account and have booked you a technician - you can check the date and time of the visit via your online account at anytime. If the appointment is not convenient you can also reschedule it via your account too 🙂
If you have any issues checking or rescheduling, please let us know.
Cheers
Katie - Forum Team
