Intermittent (but serious) upstream issues
cabbagelover
Hi All,
Desperately struggling with intermittent upstream speed issues that make it impossible to work at home.  Service status checker first reports no issues with our connection, but when asking it to check further, it confirms there is a known issue in our area being worked on.  Have called VM customer support multiple times, but all I am given is an expected fix date which is constantly missed, and apologies that they will not do anything else (no details whatsoever about what the problem actually is, no engineer visit, and no compensation).
In terms of what happens, upstream speed drops from usual 25mbps down to prolonged period of 0.1-0.5mbps.  A speed checker app suggests no issue with download speed, which remains at 275mbps.  There are no error lights on router, and in most instances the upload speed returns around 4-6 hours later - usually just as working day ends.  Working from home, I am completely unable to have video calls, upload anything to our cloud filing, send or receive emails, and print documents wirelessly.
I have managed to get through to a floor supervisor once on phone once (on 02/01/23) - advice then was that issue has been taking place since 9th December.  At the time, the supervisor suggested they had spoken directly to an engineer who was on site replacing a cable - but problem continues despite being assured it would finally be over by 04/01/23.
Issue has got so bad - and financially damaging for our working - that have yesterday ordered a temporary 5G router to use during moments of outage.  Any advice how to reclaim these costs from Virgin gratefully received, although ultimately just hoping this post might reach the expert moderators and provide means to escalate or at least give some assurance on what is going on and when it might be fixed!
Router logs to follow.  Have today set up a BQM which I will share tomorrow am.  Am fairly non-technical, but really incredibly grateful for any and all advice.  Thank you in advance!
18 REPLIES 18
cabbagelover
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
235000000
3.5
40
256 qam
13
2
139000000
2
38
256 qam
1
3
147000000
2.2
38
256 qam
2
4
155000000
2.4
40
256 qam
3
5
163000000
2.2
40
256 qam
4
6
171000000
2.2
40
256 qam
5
7
179000000
1.7
38
256 qam
6
8
187000000
1.7
38
256 qam
7
9
195000000
1.7
38
256 qam
8
10
203000000
1.9
38
256 qam
9
11
211000000
2.5
38
256 qam
10
12
219000000
2.9
38
256 qam
11
13
227000000
3.2
40
256 qam
12
14
243000000
3.7
40
256 qam
14
15
251000000
4
40
256 qam
15
16
259000000
4.1
40
256 qam
16
17
267000000
4.5
40
256 qam
17
18
275000000
4.4
40
256 qam
18
19
283000000
4.8
40
256 qam
19
20
291000000
4.9
40
256 qam
20
21
299000000
5.4
40
256 qam
21
22
307000000
5
40
256 qam
22
23
315000000
5.1
40
256 qam
23
24
323000000
5.3
40
256 qam
24
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
40.9
10
0
2
Locked
38.9
50
0
3
Locked
38.9
25
0
4
Locked
40.3
16
0
5
Locked
40.3
15
0
6
Locked
40.3
24
0
7
Locked
38.9
9
0
8
Locked
38.9
21
0
9
Locked
38.9
11
0
10
Locked
38.9
17
0
11
Locked
38.9
8
0
12
Locked
38.9
15
0
13
Locked
40.9
9
0
14
Locked
40.3
6
0
15
Locked
40.3
10
0
16
Locked
40.3
21
0
17
Locked
40.3
8
0
18
Locked
40.3
14
0
19
Locked
40.3
15
0
20
Locked
40.3
6
0
21
Locked
40.3
10
0
22
Locked
40.3
16
0
23
Locked
40.3
10
0
24
Locked
40.3
16
0
cabbagelover
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
30099959
38
5120
16 qam
10
2
43099395
37.5
5120
16 qam
8
3
23600183
38
5120
16 qam
11
4
49598737
37.5
5120
16 qam
7
5
36599227
37.8
5120
16 qam
9
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
56
0
2
ATDMA
0
0
52
0
3
ATDMA
0
0
67
0
4
ATDMA
0
0
52
0
5
ATDMA
0
0
83
0
Time
Priority
Description
19/01/2023 10:04:49
critical
19/01/2023 10:04:49
critical
Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/01/2023 10:01:33
critical
TFTP file complete - but missing mandatory TLV;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/01/2023 17:36:51
critical
16/01/2023 09:39:3
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/01/2023 05:52:12
critical
12/01/2023 21:39:3
Error
10/01/2023 00:36:39
critical
10/01/2023 00:27:52
Error
10/01/2023 00:27:50
Error
DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/01/2023 10:44:3
critical
09/01/2023 10:42:31
Error
05/01/2023 20:05:23
critical
05/01/2023 05:50:12
Error
02/01/2023 11:16:29
critical
02/01/2023 11:15:18
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2023 10:57:52
critical
02/01/2023 10:56:13
notice
01/01/2023 03:05:8
critical
31/12/2022 19:33:41
Error
So the non technical explanation is the Upstream channels are impacted confirming the experience as reported.
To see the issue in the stats, look at the Upstream bonded channels
In this case there are 5 Upstream bonded channels but all have dropped down to Modulation 16 qam.
16 qam is the slowest upstream rate that maintains a connection even when there is severe noise issues on the service.
32 qam is the medium upstream rate used when there is light noise issues.
64 qam is the fast rate for normal service. ( each 64 qam channel = 27 Mb/s of upstream bandwidth )
Once the local fault (damaged cables etc) have been repaired the Upstream channels should all come back to 64 qam.
Thank you for the reply and detail - it is appreciated.
After another very frustrating afternoon not able to work, and with continued apathy from Virgin customer service, have now arranged for disconnection. Fingers crossed a new provider will be able to give us more certainty.
Sadly Virgin Media's service can be like chalk and cheese.
Not sure how VM are doing this but they only mostly care about download speed but heres the tricky part to download you have to upload send back small ACK packets which is way more bandwidth then 1Mb for 275Mb download. So clearly VM have done some priority QoS/BWM.
example
The modem uses ACK suppression, so you need to measure at the other end, if you want to know how many ACKs that get through.
So this ACK suppression is done in modem mode too?
What if this ACK suppression in the Docsis modem is flawed causing an attacker to limit ones bandwidth in some way?
Yes, it also works in modem mode. It works by throwing away unnecessary ACKs between bursts. You should be safe from attackers. 🙂
