Intermittent and sporadic speeds
RLipscomb
Dear insightful folks,
again I am suffering from slow down on my system having not made any changes to my internal system.
I was getting 1.9 gbps down and 52 up, now since Thursday I’m seeing 600 down and 52 up!
My system is currently in router mode to diagnose issues but usually running in modem mode connected to UniFi UDM SE.
Sam knows says 1145 at the hub (but this drops to 300 at times too) which tells me all cables are ok to the hub and cat 6a goes to UDM and is known working cable but to rule out I used another new one from different batch.
this morning I rebooted the hub again and ran a speed test and it was back up to 1.9gb and thought great, then an hour or so later it’s back down to 600 again.
… rebooting hub has not helped but again Sam knows and the virgin app seem to think all is ok.
I’m in that perennial dilemma that I’ve 100% not touched anything inside house and yet I’m now second guessing where issue is .. inside or outside!
any thoughts please? Just want a bit of stability for my money!
… thanks, Rob
10 REPLIES 10
carl_pearce
Community elder
It's worth posting the HUB stats from the 'Check router status' section, and creating a BQM and posting the live link (It should omit your Public IP).
RLipscomb
Thanks @carl_pearce,
Stats attached ..
.. all looks ok to me but might be missing something!
Also, can seem to get BQM to capture anything!
Acquired Downstream Channel(Hz)338000000Locked
Ranged Upstream Channel(Hz)53700000Ranged
Provisioning StateOnline
Operational
13380000003.941QAM 25626
21380000004.141QAM 2561
31460000003.840QAM 2562
41540000003.740QAM 2563
51620000003.641QAM 2564
61700000003.540QAM 2565
71780000003.440QAM 2566
81860000003.641QAM 2567
91940000003.941QAM 2568
10202000000441QAM 2569
112100000004.341QAM 25610
122180000004.341QAM 25611
132260000004.241QAM 25612
142340000004.141QAM 25613
152420000004.141QAM 25614
16250000000441QAM 25615
172580000004.141QAM 25616
182660000004.241QAM 25617
192740000004.241QAM 25618
202820000004.241QAM 25619
212900000004.341QAM 25620
222980000004.241QAM 25621
233060000004.241QAM 25622
243140000004.141QAM 25623
25322000000441QAM 25624
263300000003.941QAM 25625
273460000003.941QAM 25627
283540000003.841QAM 25628
293620000003.941QAM 25629
303700000003.941QAM 25630
313780000003.841QAM 25631
1Locked4100
2Locked4100
3Locked4000
4Locked4000
5Locked4100
6Locked4000
7Locked4000
8Locked4100
9Locked4100
10Locked4100
11Locked4100
12Locked4100
13Locked4100
14Locked4100
15Locked4100
16Locked4100
17Locked4100
18Locked4100
19Locked4100
20Locked4100
21Locked4100
22Locked4100
23Locked4100
24Locked4100
25Locked4100
26Locked4100
27Locked4100
28Locked4100
29Locked4100
30Locked4100
31Locked410
0
05370000039.85120QAM 645
14620000039.35120QAM 646
23940000039.35120QAM 647
33260000038.85120QAM 648
0ATDMA0000
3ATDMA000
0
General Configuration
Network accessMaximum Number of CPEsBaseline PrivacyDOCSIS ModeConfig file
Allowed
3
Enabled
3.1
JKDHSUBsgvca69834ncxv9873254k
SFIDMax Traffic RateMax Traffic BurstMin Traffic RateSFIDMax Traffic RateMax Traffic BurstMin Traffic Rate
3046
1200000450 bps
42600bytes
0 bps
4452
128000 bps
4000bytes
0 bps
Primary Upstream Service Flow
SFIDMax Traffic RateMax Traffic BurstMin Traffic RateMax Concatenated BurstScheduling TypeSFIDMax Traffic RateMax Traffic BurstMin Traffic RateMax Concatenated BurstScheduling Type
3045
55000270 bps
42600bytes
0 bps
16320bytes
Best Effort
4448
128000 bps
4000bytes
0 bps
1522bytes
Best Effort
27-08-2023 15:43:54noticeREGISTRATION COMPLETE - Waiting for Operational status
27-08-2023 15:43:48warningREG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
27-08-2023 15:43:48warningDynamic Range Window violation
27-08-2023 15:43:48warningRNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
27-08-2023 15:43:43noticeDS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
27-08-2023 15:43:31warningDHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
27-08-2023 15:43:28noticeHonoring MDD; IP provisioning mode = IPv4
27-08-2023 15:43:17criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
27-08-2023 15:43:05criticalCable Modem tr069-reboot
27-08-2023 12:04:19criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
27-08-2023 12:04:06criticalCable Modem tr069-reboot
27-08-2023 11:59:17criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
27-08-2023 11:59:05criticalCable Modem tr069-reboot
27-08-2023 10:27:47criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
27-08-2023 10:27:35criticalCable Modem tr069-reboot
26-08-2023 19:04:27criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
26-08-2023 19:04:15criticalCable Modem Reboot via RG reboot command
26-08-2023 15:50:46criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
26-08-2023 15:50:29criticalCable Modem Reboot due to power button reset
26-08-2023 15:43:00criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
26-08-2023 15:42:43criticalCable Modem Reboot via RG reboot command
26-08-2023 15:20:46criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
26-08-2023 15:20:42criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
26-08-2023 15:20:23criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
26-08-2023 15:20:22criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
26-08-2023 15:20:03criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
26-08-2023 15:20:03criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
26-08-2023 15:19:43criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
26-08-2023 15:19:42criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
26-08-2023 15:18:50criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
carl_pearce
Community elder
The BQM builds up from the time you start it, unless you mean it's all red?
It appears you have a capacity issue in your area as you don't have a DOCSIS 3.1 upstream channel (A fifth upstream channel), and you are not getting 104Mbps upload.
There are also issues reported in the logs, which also point to a local outage of some sort.
IKR .. and yet, everything says it's all fine on the virgin test systems. I raised another query re the upload too and hoping someone in forum will pick that up. It might get cleared by percussion in next day, but it happens too often imho.
Be great if this could get picked up by the virgin support team to investigate and advise 🙂
Also, the BQM just does not ever capture anything, I read before hub needs to have allow WAN ping enabled but can't locate that in the hub firmware anywhere so might be an old thread I was reading.
Thanks for the info ..
Legend
"I was getting 1.9 gbps down and 52 up"   - yet this on a 1130/52 Mb/s connection.
I'm quite curious as to what speed test gave these ( way over fast downstream ) results ?
If your Hub is in Router mode try :
For Router or Modem mode try :
https://speed.cloudflare.com/
thanks, mistyped as on phone and eyes not as good as once were! 1.09gbps or 1090mbps if more precise.
.. and yes, I’ve tried all the basic real speed tests as preliminary PD but thanks for suggestion.
carl_pearce
Community elder
Yeah, not looking good!
