LethalB
  • 15
Message 1 of 7
Intermittent Wifi
Hi team,
Raising this because although there are many existing threads on this, it doesn't seem to resolve the issues, so here is the data you need to make your assessment - including setting up the Broadband Quality Monitor (sorry for so many pictures - I'd much prefer to send as one attachment).
Summary of the issue - very regular outages in wifi, as well as reduced speeds (pages lagging, video calls dropping/freezing) - I'm attributing this to the wifi falling in and out because each time if we disconnect and immediately back onto the wifi it seems to work again.  The router is wired correctly and restarting doesn't provide any relief.
28th Jan
29th Jan
30th Jan
31st Jan
1st Feb
2nd Feb
I'm not sure what if any solution there is, but it is becoming a bigger issue as both my wife and I work from home permanently now and need stability - outside of working hours it would be nice too 🙂
I don't recall if there is any additional information that would be helpful, if there is please let me know and I'll share it.  Thanks in advance for helping a desperate soul.
LethalB
  • 15
Message 2 of 7
Re: Intermittent Wifi
Latest BQM - the dropped packages at 6pm is when I reset my router.
conman33158
  • 726
  • 66
  • 95
Superfast
Message 3 of 7
Your router stats and BQM all seem healthy, I think it's just a case of a recurring theme of poor wifi from the Virgin hubs yet again. Have you tried a factory reset? Hold in the pinhole at the rear of the router for at least 50 seconds and then release (the lights will flash while holding in the pinhole reset button after about 15 seconds) then allow 5 minutes for the router to reboot and re-sync the connection.
If this doesn't solve the issue you would probably be better of investing in a decent third party router, that way you can put the Virgin Hub into modem mode and let the router deal with all the traffic. This would give you better wi-fi coverage and if you go for the likes of a wi-fi 6 capable router you would get better speeds. There are loads of options from Asus, TP Link etc and seeing as the VM Hubs are well known for their lack of wi-fi capabilities you would be better of using your own equipment, especially if you are suffering from poor wi-fi coverage and speed 🙂
tehwolf
  • 1.57K
  • 253
  • 379
Superfast
Message 4 of 7
I can't see anything screaming out in your status / logs and the BQM looks pretty clean too..
Have you done any testing with a device that is directly connected to the hub with an ethernet cable?
LethalB
  • 15
Message 5 of 7
Thanks, the latest BQM which has the redline is when I did the factory reset and it seems to be the same issues - dropping completely for 30 secs here and there, so I think it's as you suggest - more of an issue with hardware.  I was hoping to avoid spending more money but it seems more and more that this is something Virgin customers should expect.
Thanks again!
LethalB
  • 15
Message 6 of 7
Thanks, the issues aren't replicable when connected via Ethernet, but unfortunately my personal situation means we cannot find a solution for both my wife and I to work in proximity to the router, so I think it'll be a case of investing in some additional tech.
highwalker
  • 5
Message 7 of 7
Also clear that the Network Log functionality screens a lot of log issues out - mine doesn't even show when the device is power cycled, or when the WiFi chooses to reset itself, and this data is available in the hub.
