AGissel
  • 12
Message 1 of 18
Intermittent Upload Speed Issues - Is there a fault in my area?
Hi There,
For the last week or so I've been suffering with issues related to my Upload speed. I'm on the M350 package with a Hub 4. I experience the advertisted Download speeds no problem. But my upload speeds are terrible, I am a content creator outside of my normal work and require a stable upload connection. Please investigate:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/bd0f35cf5981a10b1bc2bc1a265dc5a799...
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 18
Re: Intermittent Upload Speed Issues - Is there a fault in my area?
Your BQM is certainly showing a Monday Morning utilisation problem, TBH Monday mornings are always very busy regardless of the ISP because so many people are checking emails and downloading work for the coming week.
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
AGissel
  • 12
Message 3 of 18
Thanks Mike,
I'm trying to get onto the Hub Manager now (I use in Modem Mode), but seem to be struggling. Will come back!
Alex
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 18
Use IP 192.168.100.1
AGissel
  • 12
Message 5 of 18
I seem to be stuck on this
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 6 of 18
Try rebooting the Hub using the little power switch on the rear of the Hub next to the power cord.
AGissel
  • 12
Message 7 of 18
3.0 Downstream channels
304027500001.50000038.983261QAM25630
11387500007.00000040.946209QAM2561
21467500006.90000240.946209QAM2562
31547500006.69999740.366287QAM2563
41627500006.00000040.366287QAM2564
51707500005.40000240.366287QAM2565
61787500005.09999840.366287QAM2566
71867500004.69999740.946209QAM2567
81947500004.69999740.366287QAM2568
92027500004.50000040.366287QAM2569
102107500004.00000040.366287QAM25610
112187500003.59999840.366287QAM25611
122267500003.20000140.366287QAM25612
132347500002.90000240.946209QAM25613
142427500002.79999940.366287QAM25614
152507500001.40000238.983261QAM25615
162587500002.40000238.605377QAM25616
172667500001.70000138.605377QAM25617
18274750000-1.20000137.636276QAM25618
192827500001.90000238.983261QAM25619
202907500002.20000138.983261QAM25620
212987500002.90000240.366287QAM25621
223067500003.20000140.366287QAM25622
233147500003.20000140.946209QAM25623
243227500003.09999840.366287QAM25624
253307500002.50000038.983261QAM25625
263707500002.70000140.366287QAM25626
273787500003.00000040.946209QAM25627
283867500002.59999840.366287QAM25628
293947500002.50000040.366287QAM25629
314107500002.00000040.366287QAM25631
30Locked000
1Locked3416100
2Locked929700
3Locked474170
4Locked1458900
5Locked1538100
6Locked862900
7Locked2584350000
8Locked1757400
9Locked788900
10Locked2606875500
11Locked2389000
12Locked687900
13Locked318300
14Locked1730400
15Locked875800
16Locked2667400
17Locked293000
18Locked696100
19Locked667400
20Locked1479500
21Locked1147960
22Locked293000
23Locked293000
24Locked2669100
25Locked2594500
26Locked4964100
27Locked4242456400
28Locked3091900
29Locked1524000
31Locked7328073800
3.1 Downstream channelsChannel Channel Width (MHz) FFT Type Number of Active Subcarriers Modulation (Active Profile) First Active Subcarrier (Hz)
33784K1520QAM4096424
3.1 Downstream channelsChannel ID Lock Status RxMER Data (dB) PLC Power (dBmV) Correcteds (Active Profile) Uncorrectables (Active Profile)
33Locked 1.856512830
AGissel
  • 12
Message 8 of 18
3.0 Upstream channels
12580000037.5205995120 KSym/sec32QAM6
23940000038.2705995120 KSym/sec64QAM4
34620000038.2705995120 KSym/sec64QAM3
45370000038.0205995120 KSym/sec64QAM2
1US_TYPE_STDMA0001
2US_TYPE_STDMA0001
3US_TYPE_STDMA0001
4US_TYPE_STDMA0001
AGissel
  • 12
Message 9 of 18
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
cmreg-vmdg640-bbt062+voc-b.cm
SFID
1227238
Max Traffic Rate
402500089
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
1227237
Max Traffic Rate
38500089
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
42600
Scheduling Type
bestEffort
AGissel
  • 12
Message 10 of 18
Tue 15/12/2020 18:51:496SW download Successful - Via Config file
Tue 15/12/2020 18:54:215MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 15/12/2020 19:25:364DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 15/12/2020 19:48:213No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 15/12/2020 20:21:334DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/01/1970 00:01:183No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 16/12/2020 14:50:125MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 16/12/2020 14:50:213Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 16/12/2020 17:56:093No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 16/12/2020 21:53:065MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 16/12/2020 21:53:143Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 16/12/2020 21:53:175RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 16/12/2020 21:53:496CM-STATUS message sent. Event Type Code: 5; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 19/12/2020 21:07:084DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/01/1970 00:01:203No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 20/12/2020 22:13:545MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 21/12/2020 08:36:513No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 23/12/2020 15:47:314DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 27/12/2020 20:53:353No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 30/12/2020 12:57:204DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 01/01/2021 10:04:483No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 03/01/2021 00:57:204DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 04/01/2021 12:17:235MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 04/01/2021 12:22:305RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/01/1970 00:01:173No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 04/01/2021 12:46:385MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 04/01/2021 12:46:453Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 04/01/2021 12:46:495RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 04/01/2021 12:47:116CM-STATUS message sent. Event Type Code: 4; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 05/01/2021 21:16:453No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 07/01/2021 06:51:524DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 07/01/2021 18:56:415MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 07/01/2021 18:56:493Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 07/01/2021 18:56:525RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 07/01/2021 18:57:136CM-STATUS message sent. Event Type Code: 5; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 08/01/2021 11:09:065MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 08/01/2021 12:13:063Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 08/01/2021 12:13:095RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 08/01/2021 12:13:386CM-STATUS message sent. Event Type Code: 5; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 08/01/2021 12:16:235MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 08/01/2021 12:16:313Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 08/01/2021 12:16:345RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
