ykm71
  • 5
Message 1 of 8
Intermittent Connection and Slow Speed - Yet again!
HI,
Like a number of other posts here, I am also suffering from slow speed and dropping connections.
My hub logs are:
16/07/2020 13:39:26criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/07/2020 13:39:15noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/07/2020 13:36:50criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/07/2020 13:36:31Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/07/2020 13:36:25criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/07/2020 13:35:45Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/07/2020 20:27:42criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/07/2020 20:25:56criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/07/2020 11:21:35criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/07/2020 03:34:22noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsl10016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/07/2020 03:34:22ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/07/2020 23:45:7ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/07/2020 21:52:16criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/07/2020 21:00:58ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/07/2020 15:14:47criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 07:51:31criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 07:50:5criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 01:40:25criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 01:39:46criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 01:39:34criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1434750000-2.238256 qam29
2194750000-0.438256 qam8
3202750000-0.538256 qam9
4210750000-0.538256 qam10
5218750000-0.738256 qam11
6226750000-138256 qam12
7234750000-138256 qam13
8242750000-138256 qam14
9250750000-1.238256 qam15
10258750000-1.238256 qam16
11266750000-1.538256 qam17
12274750000-1.538256 qam18
13282750000-138256 qam19
14290750000-0.938256 qam20
15298750000-138256 qam21
16306750000-1.238256 qam22
17314750000-1.438256 qam23
18322750000-1.238256 qam24
19402750000-1.438256 qam25
20410750000-1.538256 qam26
21418750000-1.738256 qam27
22426750000-1.738256 qam28
23442750000-2.238256 qam30
24450750000-338256 qam31
1Locked38.9229266559
2Locked38.648452
3Locked38.974441
4Locked38.941315
5Locked38.98795
6Locked38.612977
7Locked38.94640
8Locked38.611276
9Locked38.621840
10Locked38.93180
11Locked38.96330
12Locked38.916520
13Locked38.64090
14Locked38.62320
15Locked38.62550
16Locked38.62400
17Locked38.92160
18Locked38.62430
19Locked38.61750
20Locked38.61750
21Locked38.61780
22Locked38.61730
23Locked38.61730
24Locked38.62430
I would be grateful for any help as I have not had any from technical support after a lengthy call.
Regards.
ykm71
  • 5
Message 2 of 8
Re: Intermittent Connection and Slow Speed - Yet again!
Also, Speed Test Results:
with a wired connection.
Anonymous
Not applicable
Message 3 of 8
When was the last time the HUB was rebooted?
One of your downstream channels has a large number of 'Post RS Errors' which could point to a fault.
Power levels on the downstream channels are a little low, but in spec.
ykm71
  • 5
Message 4 of 8
Hi Carl,
Thanks for your advice.
I finally managed to get through to tech support and after several reboots and a reset plus some other changes at their end, it's back to normal.
chrisnewton
  • 87
Message 5 of 8
Hi do you have the number for tech support?
ykm71
  • 5
Message 6 of 8
HI,
I used the 0345 454 1111 number - the difference this time was that I was put through directly to the retentions team who did the additional techy bits - and the lady was very nice about it all - very different from my previous experience.
chrisnewton
  • 87
Message 7 of 8
thats great thanks so much for that
John_GS
  • 8.7K
  • 476
  • 769
Message 8 of 8
Hi chrisnewton
Have you managed to speak to the technical team since posting? If not, let me know if I can be of assistance.
Hi @ykm71, my apologies for the service issues but glad the team has got this sorted for you. Let me know if you need further assistance.
Kind regards
John_GS
