olo12345
  • 33
Message 1 of 16
Intermittent Connection, Dropouts, Latency and Speed issues since 2 weeks
I am using M350, Ethernet connection and Super hub3.
Since last 2 weeks I am constantly having problems with connection drop outs, slower speeds and high ping/latency.
It is really becoming a huge annoyance/problem as we are working from home and need stable connection.
Please could this be investigated?
Downstream:
1402750000-0.240256 qam25
2202750000040256 qam9
3210750000-0.240256 qam10
4218750000038256 qam11
5226750000-0.738256 qam12
6234750000-0.540256 qam13
7242750000-1.740256 qam14
8250750000-0.238256 qam15
9258750000040256 qam16
102667500000.540256 qam17
112747500000.540256 qam18
122827500000.540256 qam19
13290750000140256 qam20
142987500000.940256 qam21
153067500000.740256 qam22
163147500000.240256 qam23
173227500001.240256 qam24
184107500000.240256 qam26
19418750000040256 qam27
204267500000.240256 qam28
214347500000.440256 qam29
22442750000040256 qam30
23450750000-0.440256 qam31
24458750000-0.540256 qam32
1Locked40.3300
2Locked40.3221579
3Locked40.31362137
4Locked38.6144586
5Locked38.9144945
6Locked40.91076141
7Locked40.37226
8Locked38.991411
9Locked40.33463
10Locked40.33720
11Locked40.34505
12Locked40.364019
13Locked40.37382
14Locked40.36330
15Locked40.35320
16Locked40.38950
17Locked40.38100
18Locked40.3270
19Locked40.3210
20Locked40.3230
21Locked40.3240
22Locked40.3310
23Locked40.9240
24Locked40.3340
Upstream:
16030002648512064 qam9
23940000046.8512064 qam12
34620000048512064 qam11
45369992548512064 qam10
Network log:
01/01/1970 00:00:22 Error ToD request sent- No Response received;;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:55 Warning! ToD request sent - No Response received;;CM-QOS=1.1;CM-VER=3.0;
25/11/2020 10:24:2 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;;CM-QOS=1.1;CM-VER=3.0;
25/11/2020 10:24:2 Error DHCP RENEW WARNING - Field invalid in response v4 option;;CM-QOS=1.1;CM-VER=3.0;
23/11/2020 15:01:38 critical No Ranging Response received - T3 time-out;;CM-QOS=1.1;CM-VER=3.0;
22/11/2020 06:23:23 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;;CM-QOS=1.1;CM-VER=3.0;
22/11/2020 06:23:23 Error DHCP RENEW WARNING - Field invalid in response v4 option;;CM-QOS=1.1;CM-VER=3.0;
19/11/2020 18:30:42 critical No Ranging Response received - T3 time-out;;CM-QOS=1.1;CM-VER=3.0;
19/11/2020 18:30:42 critical Unicast Ranging Received Abort Response - initializing MAC;;CM-QOS=1.1;CM-VER=3.0;
19/11/2020 18:30:22 critical No Ranging Response received - T3 time-out;;CM-QOS=1.1;CM-VER=3.0;
19/11/2020 18:30:22 critical Unicast Ranging Received Abort Response - initializing MAC;;CM-QOS=1.1;CM-VER=3.0;
19/11/2020 18:30:2 critical No Ranging Response received - T3 time-out;;CM-QOS=1.1;CM-VER=3.0;
19/11/2020 18:30:2 critical Unicast Ranging Received Abort Response - initializing MAC;;CM-QOS=1.1;CM-VER=3.0;
19/11/2020 18:29:2 critical No Ranging Response received - T3 time-out;;CM-QOS=1.1;CM-VER=3.0;
19/11/2020 18:29:2 critical Unicast Ranging Received Abort Response - initializing MAC;;CM-QOS=1.1;CM-VER=3.0;
19/11/2020 18:28:42 critical No Ranging Response received - T3 time-out;;CM-QOS=1.1;CM-VER=3.0;
19/11/2020 18:28:42 critical Unicast Ranging Received Abort Response - initializing MAC;;CM-QOS=1.1;CM-VER=3.0;
19/11/2020 18:28:2 critical No Ranging Response received - T3 time-out;;CM-QOS=1.1;CM-VER=3.0;
19/11/2020 18:28:2 critical Unicast Ranging Received Abort Response - initializing MAC;;CM-QOS=1.1;CM-VER=3.0;
19/11/2020 18:27:42 critical No Ranging Response received - T3 time-out;;CM-QOS=1.1;CM-VER=3.0;
Live BQM:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/636017580d894c7b123f2265115fd4c0e3e9d361
olo12345
  • 33
Message 2 of 16
Re: Intermittent Connection, Dropouts, Latency and Speed issues since 2 weeks
Any help please?
Andrew-G
  • 8.15K
  • 1.36K
  • 3.69K
Message 3 of 16
You've tried a pinhole reset?
olo12345
  • 33
Message 4 of 16
Yep tried that, didn't help unfortunately. I also tried unplugging and waiting for like 10min before plugging back on and didn't help either.
As you can see from my live BQM link there are almost constant packet drops and big spikes in latency from time to time.
My download speed is reduced and upload is almost non existent.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 5 of 16
Deleted
Andrew-G
  • 8.15K
  • 1.36K
  • 3.69K
Message 6 of 16
I've flagged that for the forum staff to pickup - if there's not a known area problem, then you'll need a technician visit, but they can advise on next steps.
Martin_N
  • 6.21K
  • 258
  • 367
Message 7 of 16
Hi olo12345,
Thank you for your post and welcome to the community.
I'm very sorry to hear about the issue you're having with your broadband service.
I am unable to locate your account from your forum information. So I will private message you so we can get some details so we can look into this.
^Martin
olo12345
  • 33
Message 8 of 16
Hi Martin,
Do you know if the fault has been fixed today?
We have started having big connection issues again. Looks like a lot of packet loss according to BQM:
olo12345
  • 33
Message 9 of 16
Packet loss all the time now since 4PM 😟
olo12345
  • 33
Message 10 of 16
Still having issues unfortunately was the fault F008598151 not fixed yet?
