revart
Message 1 of 16
Intermittent Broadband
For the past two weeks I have been having issues with my broadband connection. The internet keeps dropping on several devices throughout the day even though I am on the M100 Fibre Broadband plan. Since I am working from home, this has has been an absolute nightmare as I keep getting disconnected from calls and loose the work in progress.
I have restarted many times but the problem is still there. I have ran a service check and it says that all is good, but it is not! My area is BL6.
Please fix this asap.
gary_dexter
  • 30.57K
  • 1.89K
  • 4.06K
Message 2 of 16
Re: Intermittent Broadband
Wired or wireless?
revart
Message 3 of 16
Wireless
gary_dexter
  • 30.57K
  • 1.89K
  • 4.06K
Message 4 of 16
Try a wired connection to see if it's more stable
Emeng
  • 5
Message 5 of 16
Has your connection been fixed?
I'm in the exact same situation. WIFI connection has been dropping off and on since last week. It's such a pain while working from home! I've done a few tests as suggested which all shows fine but I know it's not! would be grateful if you can share some tips.
Many thanks
gary_dexter
  • 30.57K
  • 1.89K
  • 4.06K
Message 6 of 16
@Emeng wrote:
Many thanks
You need to start your own thread ideally.
What is a wired connection like?
Emeng
  • 5
Message 7 of 16
Thanks for the reply Gary, my first time posting here.
I don't have the wire unfortunately. I've done speed test via the help function on VM website and it shows all good...
gary_dexter
  • 30.57K
  • 1.89K
  • 4.06K
Message 8 of 16
Wireless speeds and connections aren't guaranteed.
You need to test with a wired connection to ascertain if it's a wireless issue or an overall connectivity issue.
revart
Message 9 of 16
My router is in a different room from the one I use for work, so I cannot test/use the wired connection. And like I said, multiple devices like my mobile and other devices which can't be wired loose the connection.
The problem is still not resolved.
gary_dexter
  • 30.57K
  • 1.89K
  • 4.06K
Message 10 of 16
It will be difficult to resolve without cooperation and testing.
Post the network, upstream and downstream logs from the hubs admin pages.
