on 16-07-2022 18:31
Hi, hoping someone can help. We’ve been having issues now with Virgin Tv 360 and Broadband for weeks, it always seems to be from early evening onwards every day the broadband becomes slow and buffers, I get packet loss and can’t even play a games console. The Tv is unwatchable too with error code after error code and buffering and breaking up too. I’ve restarted the superhub3 countless times, restarted the TiVo box and checked all connections aren’t loose to no avail.
on 16-07-2022 20:10
You've mentioned a TiVo & a TV360 which are completely different services, I presume you used to have a V6 but converted it to a TV360?
It does sound like you have potential signal issues affecting both services, but this needs to be taken separately on here. Pixellation on live TV is a sure-fire signal issue, but....
I'm going to offer my standard response to "my broadband isn't working" posts and move your thread to the broadband board where those more qualified than myself, can respond to that side. VM staff should also pickup in a day or two if necessary. Also for clarity - are these issues on wired connections as well as wireless?
1: Let's get all your modem stats.. Goto to http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) but don't log in. Click on "router status", and copy & paste the data from each of the tabs.
2: If you haven't already, please setup a Broadband Quality Monitor and post a link to your live graph. It monitors your connection 24/7 and provides excellent diagnosis of any underlying issues.
on 16-07-2022 22:37
My Live Graph
https://www.thinkbroadband.com/broadband/monitoring/quality/share/b8c6a9bd4624aaf7fe2423b41718ba2357a256d6
on 16-07-2022 22:38
Acquired Downstream Channel (Hz) | 178750000 | Locked |
Ranged Upstream Channel (Hz) | 49600009 | Locked |
Provisioning State | Online |
1 | 178750000 | 2.2 | 37 | 256 qam | 6 |
2 | 138750000 | 2.9 | 36 | 256 qam | 1 |
3 | 146750000 | 3.2 | 37 | 256 qam | 2 |
4 | 154750000 | 3.2 | 37 | 256 qam | 3 |
5 | 162750000 | 3 | 37 | 256 qam | 4 |
6 | 170750000 | 2.7 | 37 | 256 qam | 5 |
7 | 186750000 | 2 | 37 | 256 qam | 7 |
8 | 194750000 | 1.5 | 37 | 256 qam | 8 |
9 | 202750000 | 1 | 37 | 256 qam | 9 |
10 | 210750000 | 0.5 | 37 | 256 qam | 10 |
11 | 218750000 | 0 | 37 | 256 qam | 11 |
12 | 226750000 | -0.5 | 37 | 256 qam | 12 |
13 | 234750000 | -0.7 | 37 | 256 qam | 13 |
14 | 242750000 | -0.2 | 38 | 256 qam | 14 |
15 | 250750000 | 0 | 37 | 256 qam | 15 |
16 | 258750000 | 1 | 38 | 256 qam | 16 |
17 | 266750000 | 1.5 | 38 | 256 qam | 17 |
18 | 274750000 | 1.7 | 38 | 256 qam | 18 |
19 | 282750000 | 1.5 | 38 | 256 qam | 19 |
20 | 290750000 | 1.5 | 38 | 256 qam | 20 |
21 | 298750000 | 2 | 38 | 256 qam | 21 |
22 | 306750000 | 1.9 | 38 | 256 qam | 22 |
23 | 314750000 | 1.9 | 38 | 256 qam | 23 |
24 | 322750000 | 2.2 | 38 | 256 qam | 24 |
1 | Locked | 37.6 | 1467 | 36489 |
2 | Locked | 36.6 | 4089 | 59428 |
3 | Locked | 37.3 | 3822 | 36470 |
4 | Locked | 37.6 | 2549 | 37079 |
5 | Locked | 37.3 | 1845 | 25504 |
6 | Locked | 37.3 | 1758 | 59234 |
7 | Locked | 37.6 | 2001 | 61109 |
8 | Locked | 37.6 | 3521 | 64466 |
9 | Locked | 37.6 | 7150 | 69720 |
10 | Locked | 37.3 | 8085 | 56693 |
11 | Locked | 37.6 | 3600 | 56352 |
12 | Locked | 37.6 | 4152 | 57654 |
13 | Locked | 37.3 | 4145 | 57830 |
14 | Locked | 38.6 | 4085 | 66266 |
15 | Locked | 37.6 | 4003 | 68748 |
16 | Locked | 38.6 | 3627 | 55931 |
17 | Locked | 38.6 | 4285 | 55764 |
18 | Locked | 38.9 | 4735 | 55845 |
19 | Locked | 38.9 | 4622 | 56799 |
20 | Locked | 38.6 | 7622 | 59209 |
21 | Locked | 38.9 | 6666 | 68425 |
22 | Locked | 38.9 | 9478 | 66273 |
23 | Locked | 38.9 | 10450 | 67685 |
24 | Locked | 38.9 | 8287 | 73864 |
1 | 49600009 | 39.5 | 5120 | 64 qam | 1 |
2 | 23600000 | 37 | 5120 | 32 qam | 5 |
3 | 30100000 | 37.5 | 5120 | 64 qam | 4 |
4 | 36600000 | 38 | 5120 | 64 qam | 3 |
5 | 43100000 | 38 | 5120 | 64 qam | 2 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 1 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
5 | ATDMA | 0 | 0 | 1 | 0 |
on 16-07-2022 22:39
Network access | Allowed |
Maximum Number of CPEs | 1 |
Baseline Privacy | Enabled |
DOCSIS Mode | Docsis30 |
Config file | ca69834ncxv9873254k;fg87d |
SFID | 8924 |
Max Traffic Rate | 230000061 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
SFID | 8923 |
Max Traffic Rate | 22000061 |
Max Concatenated Burst | 42600 |
Scheduling Type | BestEffort |
16/07/2022 19:01:22 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/07/2022 19:01:17 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/07/2022 19:01:17 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/07/2022 19:01:2 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/07/2022 19:01:2 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/07/2022 19:01:1 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/07/2022 18:17:36 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/07/2022 18:17:36 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/07/2022 17:36:41 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/07/2022 17:36:40 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/07/2022 17:36:40 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/07/2022 17:36:40 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/07/2022 17:24:28 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/07/2022 17:24:28 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/07/2022 17:24:27 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/07/2022 17:23:21 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 19-07-2022 09:49
Hey there @Conor-B, thanks for reaching out to us and a warm welcome to the Virgin Media forums.
I'm sorry to hear about the issues you're having with the Virgin TV and broadband services being intermittent.
I've had a look through the profile on the system and can see that there is a network outage causing this issue.
The engineers have given an estimated repair time of Monday, July 25th 2022 by 9am.
We do apologise for the inconvenience caused and appreciate your patience.
Is there any other query I may assist you with? Let us know.
Kind regards.
