wdmullen
  • 8
Message 1 of 14
Intermittent Broadband - No Ranging Response received
I get dropped packets from a wired connection generally after 3pm every day.  It's a real nightmare as most of us I need to do video calls - and the connection is virtually unusable. The lost packets correlate with critical errors I'm getting on the Hub, i.e "No Ranging Response received". I run network tests and everything is fine. I've call VM before and told to do a Factory Reset which I've done, but didn't fix it...
Time
Priority
Description
01/01/1970 00:01:36
critical
03/07/2021 20:57:27
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/07/2021 20:57:27
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2021 08:11:54
critical
02/07/2021 01:17:14
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2021 22:53:20
critical
28/06/2021 13:17:14
Error
25/06/2021 13:53:13
critical
25/06/2021 12:31:8
Error
21/06/2021 13:17:25
critical
21/06/2021 01:03:20
Error
18/06/2021 04:37:15
critical
18/06/2021 00:34:1
critical
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/06/2021 00:31:47
Warning!
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/06/2021 00:31:42
critical
18/06/2021 00:31:41
Warning!
18/06/2021 00:31:41
critical
18/06/2021 00:31:41
Warning!
15/06/2021 17:55:31
critical
15/06/2021 02:00:51
Warning!
  • 3.21K
  • 251
  • 700
Message 2 of 14
Re: Intermittent Broadband - No Ranging Response received
Please post your power levels, network log and Pre and PostRS errors.   Also setup a BQM here www.thinkbroadband.com/ping
Once done we can comment on your circuit.
wdmullen
  • 8
Message 3 of 14
Many thanks   Downstream bonded channels
1139000000-11.535256 qam1
2147000000-11.736256 qam2
3155000000-11.736256 qam3
4163000000-11.536256 qam4
5171000000-11.236256 qam5
6179000000-11.236256 qam6
7187000000-10.936256 qam7
8195000000-1136256 qam8
9203000000-11.236256 qam9
10211000000-11.436256 qam10
11219000000-11.536256 qam11
12227000000-11.536256 qam12
13235000000-11.736256 qam13
14243000000-1236256 qam14
15251000000-12.236256 qam15
16259000000-12.236256 qam16
17267000000-1236256 qam17
18275000000-1236256 qam18
19283000000-1236256 qam19
20291000000-1236256 qam20
21299000000-1235256 qam21
22307000000-1236256 qam22
23315000000-1235256 qam23
24323000000-1235256 qam24
1Locked35.78500
2Locked36.37190
3Locked36.62700
4Locked36.61750
5Locked36.31980
6Locked36.31770
7Locked36.61310
8Locked36.6550
9Locked36.31200
10Locked36.31050
11Locked36.61160
12Locked36.33520
13Locked36.62220
14Locked36.33840
15Locked36.65050
16Locked36.35930
17Locked36.35180
18Locked36.63040
19Locked36.31860
20Locked36.36020
21Locked35.714960
22Locked36.64660
23Locked35.711020
24Locked35.710490
wdmullen
  • 8
Message 4 of 14
01/01/1970 00:01:36criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/07/2021 20:57:27Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/07/2021 20:57:27criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2021 08:11:54criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2021 01:17:14ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2021 22:53:20criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/06/2021 13:17:14ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/06/2021 13:53:13criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/06/2021 12:31:8ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2021 13:17:25criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2021 01:03:20ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/06/2021 04:37:15criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/06/2021 00:34:1criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/06/2021 00:31:47Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/06/2021 00:31:42criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/06/2021 00:31:41Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/06/2021 00:31:41criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/06/2021 17:55:31criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/06/2021 02:00:51Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
wdmullen
  • 8
Message 5 of 14
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt060+voc-b.cm
SFID8178
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID8177
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
wdmullen
  • 8
Message 6 of 14
BQM to follow in 24 hours.
HUGE THANKS for your help.
  • 24.07K
  • 2.54K
  • 4.37K
Message 7 of 14
Down power levels are way too low. may need a Tech visit to rectify
Minimum should be -6dBmV. Is there an attenuator on the coax cable - if so try removing it and see what happens.
wdmullen
  • 8
Message 8 of 14
Thank you for suggestion. There's a lot to unplumb to get to the attenuator, so I'll provide the BQM in the first instance, and then hoping that VM engineer will intervene! Many thanks again, Will.
wdmullen
  • 8
Message 9 of 14
lotharmat
  • 2.54K
  • 188
  • 462
Trouble shooter
Message 10 of 14
Can you post a link to the Live BQM?
CLick 'SHare Live Graph' (under the graph)
Then paste the 'Direct Link' into here!
