polaar
  • 15
Message 1 of 14
Interference
I am having issues with my internet again, getting very high spikes. When i did the virgin media website test it says i have interference. Last time when the engineer was here it was better but nothing changed in the house so i dont understand it. How can i get an engineer to solve this permanently?
https://www.thinkbroadband.com/broadband/monitoring/quality/share/ce25102d1990167b631ea0f31f9c09c506...
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 14
Re: Interference
It doesn't have to be in the house, my VM Hub 3 Wi-Fi went into meltdown when the local authority / police CCTV camera on the lamppost adjacent to my house was used.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 14
Re: Interference
What is your connection like using a direct connection with a Cat 5E or better ethernet cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook ?
polaar
  • 15
Message 4 of 14
Re: Interference
I use ethernet ofc to my pc. I dont use the wifi at all just on my phone, and i have on pc constant spikes in the connection.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 5 of 14
Re: Interference
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 6 of 14
Re: Interference
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 7 of 14
Re: Interference
What does ofc mean ?
polaar
  • 15
Message 8 of 14
Re: Interference
Refresh data
Cable Modem Status
Item Status Comments
226750000
Locked
Ranged Upstream Channel (Hz)
53700000
Locked
Provisioning State
Online
1 226750000 2 40 256 qam 12
2 138750000 5.9 40 256 qam 1
3 146750000 4.9 38 256 qam 2
4 154750000 5 38 256 qam 3
5 162750000 4.6 38 256 qam 4
6 170750000 4.4 38 256 qam 5
7 178750000 3.7 40 256 qam 6
8 186750000 3.2 40 256 qam 7
9 194750000 3 38 256 qam 8
10 202750000 2.5 38 256 qam 9
11 210750000 2.4 38 256 qam 10
12 218750000 2.2 39 256 qam 11
13 234750000 2.7 40 256 qam 13
14 242750000 2 39 256 qam 14
15 250750000 2 40 256 qam 15
16 258750000 1.5 38 256 qam 16
17 266750000 2 40 256 qam 17
18 274750000 1 38 256 qam 18
19 282750000 -0.2 38 256 qam 19
20 290750000 0.4 38 256 qam 20
21 298750000 1.9 38 256 qam 21
22 306750000 2.5 40 256 qam 22
23 314750000 2 40 256 qam 23
24 322750000 2.4 38 256 qam 24
1 Locked 40.3 3216 46632
2 Locked 40.3 24046 56452
3 Locked 38.9 46008 86349
4 Locked 38.9 27854 56907
5 Locked 38.6 8177 54112
6 Locked 38.9 10854 52951
7 Locked 40.3 4452 53293
8 Locked 40.3 3022 55264
9 Locked 38.9 3917 52748
10 Locked 38.9 3752 52764
11 Locked 38.9 7974 48175
12 Locked 39.3 3039 53974
13 Locked 40.3 2828 54305
14 Locked 39.3 2345 38422
15 Locked 40.3 1707 42541
16 Locked 38.9 2111 46124
17 Locked 40.3 5881 51462
18 Locked 38.9 12792 52825
19 Locked 38.9 14305 51939
20 Locked 38.9 17768 48206
21 Locked 38.9 4204 49304
22 Locked 40.3 4153 45818
23 Locked 40.3 6489 48984
24 Locked 38.9 7807 53229
1 53700000 42.5 5120 64 qam 10
2 39400000 40.8 5120 64 qam 12
3 46200000 40 5120 64 qam 11
4 60300000 42.8 5120 64 qam 9
1 ATDMA 0 0 40 0
2 ATDMA 0 0 15 0
3 ATDMA 0 0 18 0
4 ATDMA 0 0 32 0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
ldJKDHSUBsgvca69834ncxv98
SFID 16526
Max Traffic Rate 402500089
Max Traffic Burst 42600
Min Traffic Rate 0
Primary Upstream Service Flow
SFID 16525
Max Traffic Rate 38500089
Min Traffic Rate 0
Max Concatenated Burst 42600
Scheduling Type BestEffort
Router status
Status
Downstream
Upstream
Configuration
polaar
  • 15
Message 9 of 14
Re: Interference
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 10 of 14
Re: Interference
Your Downstream Power Levels individually are all within spec but, the differential between the lowest at -0.2dBmV and the highest at +5.9dBmV is too great.
This will need an engineer to put right.
You can either call in (08:00 is the best time) or wait on here for a few days (6 to 10 days average) until one of the VM Forum Staff comes along.
