punkerisimo
Instead of 200Mbps running below 10Mbps
Hi all, I am on trial with Virgin and first problem started on 4th day 😫
I got ping 60ms and speed less than 10Mbps, any help? Message below is from self check - how do I book an engineer?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Instead of 200Mbps running below 10Mbps
There is a network issue, this will prevent engineer bookings until the issue has been cleared.
punkerisimo
Hi Mike, thanks for a quick reply.
What are my options, just sit and wait to be resolved by Virgin internally? Beside broadband, my TV channels (Sky Movies) are out of sync. Is it caused by same issue?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Probably, the V6 uses the internet to get updates.
Keep an eye on the status page every few hours.
Try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
