stuartj1977
  • 11
Message 1 of 16
Increasing number and duration of Intermittent dropouts
I am placing a post for some feedback, but my initial feeling is that I will require a Virginmedia response.
I am a long term Virginmedia customer and this is the first instance where I have experienced issues on the broadband package.   Receiving M200 broadband and have been active and stable for a very long time.  Over the last two to three weeks I have been experiencing drop-outs where the speeds drop from 200 plus Mbps to below 10Mbps.  Hub3 set up in Modem only mode and a WIFI mesh installed.  I have performed the speed tests utilising the mesh and cat6 connection directly to the modem to prove the connection drop out is the Virginmedia Broadband and not the WIFI network.
Pulled modem status and network quality testing in posts to follow:
Cable Modem Status
Item
Status
Comments
139000000
Locked
Ranged Upstream Channel (Hz)
46200000
Locked
Provisioning State
Online
stuartj1977
  • 11
Message 2 of 16
Re: Increasing number and duration of Intermittent dropouts
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
139000000
-1.2
37
256 qam
1
2
147000000
-1
37
256 qam
2
3
155000000
-1.2
37
256 qam
3
4
163000000
-1.2
37
256 qam
4
5
171000000
-1
37
256 qam
5
6
179000000
-1
37
256 qam
6
7
187000000
-1
38
256 qam
7
8
195000000
-1.5
38
256 qam
8
9
203000000
-1.7
38
256 qam
9
10
211000000
-1.5
38
256 qam
10
11
219000000
-1.5
38
256 qam
11
12
227000000
-1.7
37
256 qam
12
13
235000000
-1.7
38
256 qam
13
14
243000000
-2
38
256 qam
14
15
251000000
-2.4
38
256 qam
15
16
259000000
-3.4
37
256 qam
16
17
267000000
-3.5
38
256 qam
17
18
275000000
-3.7
37
256 qam
18
19
283000000
-2.7
38
256 qam
19
20
291000000
-2.2
38
256 qam
20
21
299000000
-2.5
38
256 qam
21
22
307000000
-2.2
38
256 qam
22
23
315000000
-2
38
256 qam
23
24
323000000
-2.2
37
256 qam
24
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
37.3
66137880
8378642
2
Locked
37.6
12379212
2431519
3
Locked
37.3
29055868
10281833
4
Locked
37.6
41014187
17044289
5
Locked
37.3
65843321
2584060
6
Locked
37.6
165703245
16200006
7
Locked
38.6
233479514
9342694
8
Locked
38.9
103504811
428721
9
Locked
38.6
2615167
225558
10
Locked
38.6
370545
9954
11
Locked
38.9
315143
5589
12
Locked
37.6
972036
180707
13
Locked
38.9
1164162
221343
14
Locked
38.6
453610
148925
15
Locked
38.6
149512
3977
16
Locked
37.6
1168386
109921
17
Locked
38.6
2376946
837668
18
Locked
37.6
2392014
663937
19
Locked
38.6
410925
86647
20
Locked
38.6
823108
244179
21
Locked
38.6
1830867
674095
22
Locked
38.9
1616384
447468
23
Locked
38.6
290383
840
24
Locked
37.6
273081
2058
stuartj1977
  • 11
Message 3 of 16
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
46200000
50.3
5120
64 qam
3
2
53700010
50.8
5120
64 qam
2
3
39400000
49.5
5120
64 qam
4
4
60300000
51
5120
64 qam
1
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
70
0
2
ATDMA
0
0
7
0
3
ATDMA
0
0
16
0
4
ATDMA
0
0
15
0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt060-b.cm
SFID
34800
Max Traffic Rate
230000061
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
34799
Max Traffic Rate
22000061
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
42600
Scheduling Type
BestEffort
stuartj1977
  • 11
Message 4 of 16
Time
Priority
Description
23/01/2021 12:34:9
Warning!
RCS Partial Service; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/01/2021 12:31:0
critical
23/01/2021 12:12:14
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/01/2021 08:51:16
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/01/2021 08:50:49
critical
23/01/2021 08:50:37
critical
23/01/2021 08:50:25
critical
23/01/2021 08:50:0
critical
23/01/2021 08:50:0
critical
23/01/2021 08:49:30
critical
23/01/2021 08:41:18
critical
23/01/2021 08:38:52
Warning!
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/01/2021 08:37:57
critical
23/01/2021 08:30:51
critical
23/01/2021 08:30:28
critical
23/01/2021 08:27:29
critical
23/01/2021 08:26:59
critical
23/01/2021 08:23:46
critical
23/01/2021 08:22:23
critical
23/01/2021 08:19:25
critical
stuartj1977
  • 11
Message 5 of 16
<a title="Broadband Ping" href="https://www.thinkbroadband.com/broadband/monitoring/quality/share/0b9e731898771d6c677ab947f0c4026845275722-23-01-2021"><img alt="My Broadband Ping - Virgin Home" src="https://www.thinkbroadband.com/broadband/monitoring/quality/share/thumb/0b9e731898771d6c677ab947f0c4026845275722-23-01-2021.png" /></a>
stuartj1977
  • 11
Message 6 of 16
stuartj1977
  • 11
Message 7 of 16
conman33158
  • 726
  • 66
  • 95
Superfast
Message 8 of 16
Your upstream power settings are too high and you have a lot of errors.
Have you tried rebooting the router or a pinhole reset at the back of the router, hold in for at least 50 seconds and give 5 mins to reboot 🙂
stuartj1977
  • 11
Message 9 of 16
Thanks for taking the time to respond.  I have done both some quick power re-sets of the hub3, and I have also performed a factory re-set of the hub3 which gave a temporary reprieve of the intermittent issues of about 24 hours before the drop-outs started to re-occur.
conman33158
  • 726
  • 66
  • 95
Superfast
Message 10 of 16
Sounds like you have a fault on the line my friend, you would still need an engineer to put the power levels right. Best to ring VM after 8am to arrange this or you can wait here for an answer from a Virgin rep, although this could take 5-7 days sometimes sooner sometimes longer.
