odholmes
  • 5
Settling in
Message 1 of 9
Inconsistent/slow speed & very high latency
Hi there. For around 3-months now I have been experiencing very inconsistent speeds on my fibre connection (supposed to be 200 mbps). But most importantly, the latency on the line is awful and it really impacts video calls and my ability to work from home. This happens on wifi and wired connections. I have restarted my equipment multiple times.
Example from fast.com https://share.getcloudapp.com/12uNgoKp - especially bad this evening!
I'm posting here because I've had no luck phoning customer services, they simply don't answer when I try. I think an engineer visit is required, but again, I can't get through to book one.
Has anyone got any ideas about what to try?
Many thanks
gary_dexter
  • 30.51K
  • 1.89K
  • 4.05K
Message 2 of 9
Re: Inconsistent/slow speed & very high latency
Post the network, upstream and downstream logs from the hub admin pages
odholmes
  • 5
Settling in
Message 3 of 9
Realised that screengrab link doesn't work. This should:
https://share.getcloudapp.com/12uNgo2X
odholmes
  • 5
Settling in
Message 4 of 9
Thanks. Assume you mean these?
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
1402750000538256 qam25
22187500001.438256 qam11
32267500001.237256 qam12
42347500001.238256 qam13
52427500001.538256 qam14
62507500001.438256 qam15
72587500001.537256 qam16
82667500001.938256 qam17
9274750000238256 qam18
102827500002.538256 qam19
112907500003.238256 qam20
122987500003.538256 qam21
133067500003.738256 qam22
143147500004.538256 qam23
153227500004.938256 qam24
16410750000538256 qam26
174187500004.638256 qam27
184267500004.938256 qam28
194347500004.638256 qam29
20442750000438256 qam30
214507500004.138256 qam31
224587500004.538256 qam32
23466750000438256 qam33
244747500003.738256 qam34
1Locked38.600
2Locked38.960
3Locked37.670
4Locked38.650
5Locked38.630
6Locked38.660
7Locked37.600
8Locked38.640
9Locked38.650
10Locked38.660
11Locked38.650
12Locked38.650
13Locked38.6190
14Locked38.650
15Locked38.900
16Locked38.6190
17Locked38.660
18Locked38.650
19Locked38.960
20Locked38.970
21Locked38.940
22Locked38.9180
23Locked38.950
24Locked38.900
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
1326000414.95512064 qam5
2394000074.95512064 qam4
3461999644.85512064 qam3
4536999174.65512064 qam2
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA0000
gary_dexter
  • 30.51K
  • 1.89K
  • 4.05K
Message 5 of 9
Stats look fine.
Was that a wired or wireless speedtest?
odholmes
  • 5
Settling in
Message 6 of 9
That was wireless. The wired test is better, I just got 92mbps, 19ms latency. Which again is poor given I'm on a 200mbps package. I've also tried before and wired varies wildly as well. The problem is the room I work in the only option I have is wireless as I can't run cable all the way upstairs. The VM box should be offering a satisfactory speed, not a constantly choppy one.
gary_dexter
  • 30.51K
  • 1.89K
  • 4.05K
Message 7 of 9
90odd Mbps on a wired connection could mean a CAT5 cable or a NIC that doesn’t support 10/100/1000.
Can you confirm?
odholmes
  • 5
Settling in
Message 8 of 9
It's CAT.5E direct into laptop
gary_dexter
  • 30.51K
  • 1.89K
  • 4.05K
Message 9 of 9
Have you ever gotten more than 90odd on the laptop?
