Hi @Weeblefaice
Your BQM pictures were rejected by the system as they contain your ip address.
Can you either redact the ip address and repost them, or do the following instead whic will post a live BQM please?
On Think Broadband go to your BQM and under the options you will see
Today | Previous Days | Edit | Delete | Share
Click on the Share option and on the screen that opens click on Share
On the next screen click on Share Live Graph
Copy the text in the Direct Link box (beware there may be more text than you can see so make sure yuo highlight it all)
On here when creating your post click the Link icon (2 links chain to the left of the camera icon)
In the URL box paste the link you copied and then click OK.
It would be useful if you could also post your hub stats.
In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) and hit return.
Don't login, instead below there click on Check Router Status
From the Router Status page copy/paste 3 FULL sets of data as text (not pictures) onto here – from the Downstream, Upstream, & Network Logs pages.
When you come to posting the info from the Network Logs tab you will get an error message, ignore the error and press post again and it will go through.
DaveI don't work for Virgin Media.
The do's and don'ts. Keep the community welcoming for all.
Follow the house rules The Service you do for others is the rent you pay for your room here on Earth - Muhammad AliLove, love and love, forever - Pele
